Yamaha / Monitor 70 bi wire question
Schwingding
Hi all. I have a Yamaha HTR 5990 that supports bi wire/bi amp speaker connections. I have a new set of Polk Monitor 70's that support the same.
The Yamaha manual is either confusing or bumming me out. It says that in order to use the bi wire/amp feature I must use the Main speaker A outputs and the surround back outputs. One of the diagrams, however, shows the bi wire connections being made through main A and B terminals. I am uncertain which is true.
I have surround back speakers in my system, so if the bi amp feature requires use of those outputs, I'm out of luck.
Any help appreciated.
Schwingding
Schwingding
HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
Yamaha 5990 AVR
Onix SP3 tube amp
Polk CSi5 center
Bedroom rig
Onix Ref 1 monitors
Velodyne minivee
Post edited by Schwingding on
Welcome to the forum.
I'm not sure you would be gaining much going this route. The power supply on typical receivers are not designed and built to provide any substantial improvements over single wire hook-up.Tschüss
Zach -
Schwing, another welcome. Although you connected them with a slash mark, the biwiring and biamping provisions on your Yamaha are completely separate. The biwiring is merely a parallel connection to the same amp channel by using the main A and B terminals and is essentially meaningless electrically. The biamping connection uses the main amp A terminal and the amp channel for the back surround(if it wasn't already being used for a back surround speaker, which you're doing)to drive the separate bass and treble sections of the speaker.
Don't be thinking that you're losing anything of significance by not biwiring or not being able to use the back surround amps for biamping. That form of passive biamping simply uses a different output transistor(s)to power the separate sections of the speaker, but all of the power comes from the same power supply section of the receiver and isn't increased. In particular, note that this doesn't "double" the available maximum power, as is sometimes claimed by those not well-informed on the subject.
