Polk RTi10 setup
alin22
alin22 Posts: 3
edited June 2006 in Speakers
Hello, I have a pair of Polk RTi10 speakers and one subwoofer Velodyne DPS12. I just bought a Harman Kardon AVR 635 receiver and I am trying to set it up. After running the EzSetUp, I didn't get the results that I expected (not too defined midrange, bass is not tight).
Can anybody can help me setting it up manually, please.
First, would the RTi10 qualify as Large or Small speakers?
Which is the recommended crossover frequency for the subwoofer?
Any other suggestions?
Thank you,
Alin
Toronto
Post edited by alin22 on
  • Willow
    Willow Posts: 11,073
    edited June 2006
    You can set your 10s to small w/ a xover at 80hz. Now these are recommendations only.
    They are "large" in size, yes but your sub will do the hard work.
    FWIW I have my 8s set at 60hz set to small. What I did was run the ezset on my HK then went in and manually adjusted what I wanted.
