Loose top on 2.3TL
riglehart
riglehart Posts: 276
edited June 2006 in Vintage Speakers
One of my 2.3TLs has a loose top. The 1 inch thick peice of walnut that covers the top moves back and forth about a quarter inch, but not up and down. Are these supposed to come off? I don't want to force them. The other side is solid.
Is this only cosmetic, or do I need to start glueing to seal up air leaks.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • jtgranby
    jtgranby Posts: 887
    edited June 2006
    I have never taken mine apart but according to a very well respected member he took out one the mids and tightened it from the inside. I'm sure one of the more senior members will speak up soon.;)
    JT
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2006
    Yep, get out your socket set.
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2006
    Nothing a few long nails and a good hammer can't fix.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    F1nut Posts: 51,776
    edited June 2006
    That's walnut veneer over particleboard.
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited June 2006
    Just tighten the nut inside. There are a total of 4 (one in each corner) on each cap.
  • riglehart
    edited June 2006
    Thanks. That makes sense. I'm on it.
    Jolida Tube
