Do they make EQ's with speaker inputs/outputs?
edited June 2006 in Electronics
I live in an apartment, with a 5.0 setup, and I'm trying to eliminate all or most sounds from like 120-200hz on down. The highest setting for the crossover in my receiver is 120hz. When I select it, though, I still feel like there's too much bass coming from my speakers.
Also, the tone setting in the receiver only affects the front speakers, and truthfully, it doesn't even do much in that regard.
So, anyway, do they make EQs for this purpose, that I could run between the speaker outs on my receiver and the speaker ins on my speakers? Or if not, is there a cheap way to work around it? Or should I just buy some small satellite speakers? Thanks.
Post edited by AllTheTimer on
Welcome!
    edited June 2006
    Try "night mode" in your receiver! This will lower the spl on the low frequencies, among other technical details I don't remember. I am in an apt. and use it on my Yamaha HTR.
    DKG999
    edited June 2006
    also you might want to turn the subwoofer mode to "on" if it isn't selected already. that way the low frequency effects will not be sent to your other speakers. Other than that, you might try room treatments to block some of the lower frequency.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
    edited June 2006
    Thanks for the tips--all those things definitely help. But I think I figured out what I need to do. I need to buy a new receiver.
    I just noticed on a few new receivers that they have crossovers all the way up to 250hz. I never knew that. That solves my problem completely.
    Back when I was shopping for receivers a couple years back, I didn't see any crossovers over like 160. Guess that's something new. Seems kinda crazy to buy a new receiver just for the crossover, but oh well...
    edited June 2006
    To the original post, no... never have heard of such a thing. For EQ purposes, you would need to convert the high level/speaker level signal down to line level so the EQ can be added... then amplify the signal back to speaker/high level. So basically that's a receiver. Good call on getting a new receiver :)
    Brian Knauss
    ex-Electrical Engineer for Polk
    edited June 2006
    Lol, thanks. When you break it down like that, I was defintiely making things more complicated than they need to be. Hopefully the crossover will do the trick.
Welcome!
Welcome!
