What makes a high quality driver?
Early B.
Early B. Posts: 7,900
edited June 2006 in Speakers
What is it about the design and manufacture of a driver that makes it "high quality?"
"God grooves with tubes."
Post edited by Early B. on
  • Early B.
    edited June 2006
    I'm asking for two important reason:
    1. I really want to know; and
    2. I'm trying to get my post count up to 3,000 before the end of the night.:p
  • okiepolkie
    okiepolkie Posts: 2,258
    edited June 2006
    Well, I think a well designed, high quality driver involves two things:
    1) Parents must educate their children/teenagers on how to multitask.
    2) Children/teenagers must be willing to be a little forgiving of parental involvement when it comes to actual driver education.
    If this isn't what you want, then you are beyond help ;)
    Tschüss
    Zach
  • speakergeek
    speakergeek Posts: 555
    edited June 2006
    1) Parnets must educate their children/teenagers on how to multitask.
    Now that's freekin' funny! :D
  • speakergeek
    edited June 2006
    Concerning driver functionality, the best design will yield the most accurate sonic reproduction with the least distortion. A high quality driver (speaker) should do this.
  • Early B.
    edited June 2006
    Let me be more specific -- from a technical perspective, what is it about a "high quality" driver that makes it better than most others? Is it the material used (paper vs. kevlar vs. aluminum, etc.), the magnet, the voice coil, etc.?? Or is the design more significant than the materials used to build it? Or is the crossover (its design and component quality) more important than the driver?
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited June 2006
    ****. :rolleyes:
    mhardy6647 Posts: 35,029
    edited June 2006
    Powerful motor.
    Massive, nonresonant basket.
    Top quality materials.
    Here is an example of a quality driver.
    (OK, technically it's two drivers, since it is a coax, but you get the idea...)
