CD players and digital in/out
riglehart
riglehart Posts: 276
edited June 2006 in Electronics
I've always used the 2 channel analog inputs for my cd player. I have a simple questions...
If you use the digital connection into your receiver, will any old CD player work just the same as an expensive one, since the receiver is doing all the D/A work? The CD player is just ripping info from the CD and sending it directly to the Receiver, correct? Sound quality then becomes only a function of the Receiver's circuitry, I would guess.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • danger boy
    danger boy Posts: 15,722
    edited June 2006
    using the DAC's from your receiver could yes have a different sound then the analog hook up from your CD player. Where people really hear a difference is when an external DAC from the CD players digital output to a stand alone DAC using either coax or optical connection.
    I switch between my pre amp and CD player using both analog and digital connection... and I don't hear much difference.. i can notice the difference between the two.. but it's subtle. Once i include a stand alone DAC, the difference is quite noticable.
    I know you didn't ask about an external DAC.. but i just mention that to make a point.
    good luck.
    PolkFest 2012, who's going>?
  • Willow
    Willow Posts: 11,218
    edited June 2006
    DB it does make that big of a dif? what price would you have to pay for a DAC in order to notice a difference.
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2006
    The CDP's transport also makes a difference, so no, a cheaper CDP would not be as good as a more expensive one, if you're using the receiver's DAC. A nicer transport won't have so much jitter and such. I don't understand all I know about this subject, but suffice it to say that there are SQ improvements to be had with nicer CDPs.
    And as a rule, the DACs built-in to receivers aren't usually that great. Now, whether they're better than your CDP's DAC depends on your CDP. Let your ears decide that.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • AndyGwis
    AndyGwis Posts: 3,655
    edited June 2006
    My CD player (Pioneer 59avi) has better DACs than my receiver, in my opinion, however, the bass management of the HK635 is better. So, there is quite a difference in the sound from analog and digital connection in my system.
    For clarity and vocal tracks, I use the analog outs. For CDs where I want to hear more bass, I use the digital out.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Willow
    edited June 2006
    FWIW, I use a good pair of ICs, not digital for my cds.
  • danger boy
    edited June 2006
    external DAC's don't start out that expensive.... say around $250 on up to as high as thousands and thousands of dollars. you can find lots of DAC's in the $300 to $500 range though too.
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    If your equipment has high enough resolution, most will hear a difference between transports. My CEC CD-3300 is definitely a better transport than my Denon DVD-2910. I tried to use the Denon as a all-in-one solution, that lasted about 3 days.
