To bi or not to bi wire?
I am considering bi wiring my lsi 15's. I will be using an acurus 200X3. What will the benifits be? Should I also bi wire my other speakers, or is there a need to? My only concern with this 2 channel setup is that the imaging could be sharper, more accurate (pinpoint) if that makes sense. I don't know if this is a shortfall of the speakers, or amp. I know it takes a lot of fine tuning with placement, but I am limited and am unable to move the fronts. They are 8 feet apart and I am 13 feet away. Should the speakers be toed in towards me or straight ahead, I have been playing with this. Any help would be appreciated.
If you can catch it, I can cook it.
Pioneer Elite vsx72txvi
Pioneer Elite dvd36
Toshiba DR5SC dvd recorder
Moxi HD DVR
Acurus 200X3 (by mondial)
Adcom GFA-545
Monster Line Conditioner
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch.
Post edited by pal51961 on
The only way to know if there are benefits to bi-wiring is to try it. For some, it makes a slight difference and to others it makes no difference at all.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Have to give it a shot would be my advice, on my rig I'd say I notice a slight difference. Nothing that made the earth move in my book...Rockin' In My House
Pioneer 50 inch Plasma TV
Denon AVR-3806
Denon DVD-1930ci
Polk Montor 70's
Polk PSW-12
Polk CS2
Polk Monitor 40's
Sirius Satellite Radio, Monster 3500MKII -
As far as toe in goes, point them RIGHT at you in the listening position. The preamp (Pioneer ?) is the weak link in your music chain, imo. Bi-wiring can offer an improvment, at the minimum, replace the stock jumpers with a small length of good speaker cable. You can also buy terminated jumpers from several good cable manufacturers.
Cheers,
In most cases your money would be better spent on one set of very good speaker cables versus 2 sets of medicore cables...just a thoughtSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Why do you say that my pioneer is the weak link. It is a 1300.00 receiver, and it has recieved stellar reviews. Since it is only acting as a preamp/processor I am hoping that it is able to perform this task, and it is not the problem.....but I may be wrong. What would a good set of speaker cables be? I am using monster 12 guage.If you can catch it, I can cook it.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch. -
St. Louis huh? I'm from STL.
Anywho, I know there's good audio shops in STL, see if you can do some free auditions of different speaker cables; Audioquest/Kimber/MIT/Cardas...the list goes on & on. Some of the best values are Audioquest Bedrock, Kimber 4TC or 8TC, stuff from Analysis Plus...get your research on!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
pal51961 wrote:Why do you say that my pioneer is the weak link. It is a 1300.00 receiver, and it has recieved stellar reviews. Since it is only acting as a preamp/processor I am hoping that it is able to perform this task, and it is not the problem.....but I may be wrong. What would a good set of speaker cables be? I am using monster 12 guage.
i know this may not be an important point.. but are you using monster 12 guage cables or wires? I started with monster wires too.. then moved to monster speaker cables.. and have since moved on to something else.. i am satisfied with what I am using now... Cobalt Cable ultimate speaker cables..
You will probably notice a improvement once you get different speaker cables for your rig..PolkFest 2012, who's going>?
+1! Excellent for the money.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Bi-wiring...you should try it to see if it offers an improvement. However, like others have said, I would invest in a good set of quality, higher guage speaker cables before worrying with biwiring. However, if you (and you should) get a new set of speaker wires, you may want to investigate getting a set wrapped for biwiring.
As for your Pioneer receiver acting as a pre...I don't care how expensive it was/is. It's a HT receiver. It's NOT going to do near as well as a dedicated stereo preamp, even one costing much less. Even a dedicated HT preamp (to replace the receiver in case you don't want to have a stereo preamp and a HT preamp/your receiver) would most likely offer better 2-channel performance.
Having said that, the LSi series' performance is very dependent upon placement. Play with toe-in. Like Russ said, they should be pointing right at you. See if that helps.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
What about shoe-in?
I noticed a subtle improvement when I replaced the stock-jumpers, and yet another subtle improvement when I bi-wired. Taken together, the change for the better is obvious IMO.
I have to agree on going with some quality speaker cables. There are many affordable options out there, many of which have already been mentioned.
In most cases, much of the cost will go towards the actual cables with a relatively small charge alloted to the option of bi-wiring.
In which case, it's really a no-brainer.
+1 to Signal Cable btwI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
If you're looking for better 2-channel sound, you'll need a good CD player. In addtion to a preamp and better speaker cables (and interconnects), add a minimum of $500 to your budget for a decent used CD player.
The problem with mixing HT and 2-channel is different objectives for both. It's not easy to do unless you start by building your 2-channel system first, then build an HT system around it.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
audiobliss wrote:Bi-wiring...you should try it to see if it offers an improvement.
+1
So what I am hearing is to go buy some cables, thats no problem. I only need 2-5ft's. What concerns me is how can you have a great preamp and great ht all in one, or is that the inherent shortfall of these types of systems. Don't get me wrong, it sounds great....and I love listening to this system. It has good, clean and dynamic power and lots of finess. I listen primarly to jazz and rock. The 15's with 250wpc really sing. Someone mentioned needing a cd player of quality. I have sometimes used my Ipod through the pioneers dedicated Ipod port and it sounds great to me, is this a good digital signal? Thanks for the suggestions.If you can catch it, I can cook it.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
What's the bitrate of the music you have on your iPod?
If you really enjoy critically listening to your music, hearing every minute detail, picking it apart, placing people on the stage in your mind, then you will hear great improvements with a dedicated CDP and a good quality stereo preamp.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
i believe most of it is in the 128-192 rangeIf you can catch it, I can cook it.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
If you're satisfied with the sound quality a MP3 file ripped at a bit rate of 128-192 offers, then the LSi series is most definitely overkill for you.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Agree with what some of the others have said about a better CDP. The newer Denon's have gotten some really good reviews for both CD and DVD performance.
It has been my experience and alot of extra money (not well spent), that in my audio systems, upgrading the speaker crossovers brought significantly more improvement than any interconnect, speaker cable or power cord. I have owned and still own cables from Electraglide, Ridge Street Audio, Nirvana, NBS and Siltech. No slouches in the audiophile community but dollar for dollar, nothing comes close to upgrading the internal parts of my speaker crossover networks.
Upgraded networks less than $225 vs. over $2K in cables -
pal, lsi's are not overkill for you. you identified imaging as a weakness and i'll bet you came as close as anyone here to identifying what should be addressed first to get yourself on the right path. the gear you have now is capable of giving you more precise imaging without component upgrades.
it might help you to take your time and read about and experiment with "speaker placement", "room acoustics" and "acoustic treatments". google up those terms with the quotation marks and see where they lead you.
i know you said you can't move your mains, but out of the gates you might consider playing with closer listening positions, even if only temporary or just to hear different aspects of what your gear can do and what your room does to the sound that comes out of your speaks. in many rooms slowly moving your listening position down the centerline as a tune plays can be very revealing.
it takes thought, patience, experimentation and lots of time in the listening chair to get yourself in a position that allows you to hear the best your gear and room have to offer. but remember that that is just a vehicle to allow you to set something up that lets you forget about what sounds right and wrong so you can just enjoy your tunes. you will be better served in the long run if you spend time now learning how to get the best out of what you have before jumping on the gear swap express and it will allow you to hear what changes upgrades make.
good luck and enjoy the ride.
Bliss,
The ipod was just me playing around with it, what I was curious to know though is this. By asking the bitrate of my mp3's leads me to believe that 320 might be acceptacle for high quality listening, it this true. I usually listen to my elite dv/cd. I really wasn't looking to puchase more gear. I thought I had a nice rig, being in the moderate price range. I have already ordered signal bi wire cables, so thats one thing done. I know my amp and speakers are good. If all I need is a good cd player I will buy one used on audiogon or ebay. What players do you like? I will not be willing to part with my elite reciever yet, I like looking at it!! And I think it sounds great on ht. Thanks for your help on this.If you can catch it, I can cook it.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Scott,
Thanks for confirming my thinking. Granted, as discussed I could use cables (which I ordered) and possibly more. I agree that speaker placement is critical. I also agree that I could obtain better imaging and soundstage. Since my original posting I have achieved transparency, a great soundstage and better imaging. With a great sub and great fronts amped well I think I can enjoy the accuracy and tonal beauty of this rig. It just sounds warm and lush with jazz. These tweeters are very good. All types of music seem to be handled with finesse and punch at any volume. Thanks for your suggestions and I will try them.If you can catch it, I can cook it.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch.
