Does this really work?
schipwrk
I have two 10 inch subs in a box that is separated by a wall in the back of my jeep
I was told that I should cut out a 1 ½ inch hole on the corners of the box to let air flow
and to stuff that **** with some cotton. Would this be worth the effort and would it make that much of a difference in sound? Or how would it sound? Does anyone know or has anyone done this to there subs?
Post edited by schipwrk on
I would think sound quality would go to hell, but you might get a few more db with it being "ghetto ported"dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
Sealed enclosures sound better anyway. You have 2 drivers, so a few extra db's shouldn't really matter that much. As long as the air space meets the driver's requirements, I would just make sure you are giving them all the power they can handle.__________________
Pioneer 1015
Rotel 1080
Rotel 1075
Rti10: L/R
Rti5: C
Rti6: LS/RS/LSB/RSB
SVS pb10-isd
