CableCard HD surround
marcpam
I am yet to receive my Samsung HLS6188W and I will be using the CableCard for HD channels. How would I get 5.1 surround out of the programming since I won't be using a converter hd box
Post edited by marcpam on
Yes...your tv should have a optical output that connects to your preamp/receiver.
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
If it has cable card then it has a optical out on the back of the set, you would use that to get your surround sound.
Jared -
I called Samsung earlier and they said that i needed to run analog cables from the tv to receiver. This don't sound right to me. It does have an optical port on the back of the tv.
Learning myself here also, but I think it maybe a nice option for RCA analog R/L for does 2.0 shows. This is what I plan to do Optical and R/L in changing audio mode when to need arise.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
marcpam wrote:I called Samsung earlier and they said that i needed to run analog cables from the tv to receiver. This don't sound right to me. It does have an optical port on the back of the tv.
That's OK as optical audio out isn't 100% perfect. IMHO
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:Learning myself here also, but I think it maybe a nice option for RCA analog R/L for does 2.0 shows. This is what I plan to do Optical and R/L in changing audio mode when to need arise.
I will only use my surround sound for hd channels, i will use the regular tv speakers for normal cable. -
I haven't used my regular TV speakers for anything. // Prologic II all the way.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
marcpam wrote:I will only use my surround sound for hd channels, i will use the regular tv speakers for normal cable.
But having said that some of mine Local HD channels are in DD5.1 format using 2 channel only, completely messing up my AVR as I get 2 channel only not even so so 5.1. :rolleyes: So I think 2 channel is better for this occasions.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:But having said that some of mine Local HD channels are in DD5.1 format using 2 channel only, completely messing up my AVR as I get 2 channel only not even so so 5.1. :rolleyes: So I think 2 channel is better for this occasions.
your receiver can't automatically switch between DD and DDPLII?
at least that's what I think is what's happening on mine -
Well it can if done with the optical input, but what I'm saying is that DD 5.1 input wasn't DD5.1 at times but just 2 channels L/R. So the reciever say's OK DD5.1 I'm "Done" 5.1 in 5.1 out. So when the local channels / shows mess up I need to go the analog input so my center channel / rear speakers are working.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
