Separate Cd player
Home Theatre
Home Theatre Posts: 469
edited June 2006 in Speakers
I notice that most people run a seperate cd player. Is there any reason for this or is it just better sound?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
    F1nut Posts: 51,686
    edited June 2006
    Better sound......make that the possibility of much better sound is the reason.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2006
    yes, then you can smoke your pipe and make small gurnting approval noises, I can recommend several pipes and brands of tobacco for you.
    In a nutshell, Hi-Fi is about getting the purest signal from the software to the speaker, specialization is generally held as one of the key's for the system.
    RT1
  • pal51961
    pal51961 Posts: 36
    edited June 2006
    Can you buy an integrated amp/cd player?
    If you can catch it, I can cook it.
    Pioneer Elite vsx72txvi
    Pioneer Elite dvd36
    Toshiba DR5SC dvd recorder
    Moxi HD DVR
    Acurus 200X3 (by mondial)
    Adcom GFA-545
    Monster Line Conditioner
    Polk LSI 15
    Polk LSI 9
    Polk LSI C
    Hsu VTF-2 Sub.
    Sony SXRD 60 inch.
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    I believe Musical Fidelity makes one...
    F1nut Posts: 51,686
    edited June 2006
    Steve is close. MF made a pre amp/CD player, but no longer.
    yes, then you can smoke your pipe and make small grunting approval noises
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2006
    Arcam makes the SOLO
    http://www.aslgroup.com/arcam/ArcamSoloStereophile.pdf
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2006
    In the 2-channel, music world, a separate CD player is a necessity. I'm sure a combo unit from MF or Arcam wouldn't make for a bad setup, but speaking in general, you don't want to rely on a CD changer, DVD player, or CD player/preamp combo as your main source. You can do a lot better in quality (both build and sound quality) going with a separate, stand alone unit.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
