I had a dream...
I-SIG
I-SIG Posts: 2,243
edited June 2006 in 2 Channel Audio
...the other night. It was the first dream I actually remembered in weeks, maybe months.
Anyway, I actually dreamt that I had gotten a tubed pre and was hunting for the right tubes to fit it. Pretty crazy. I can't remember any of the specifics.
On a serious note, I was thinking about getting the MF buffer to play with. I figured I could move it pretty easy if it didn't do anything for me, but I also think I need to get off my **** and upgrade my tweeters first.
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • ND13
    ND13 Posts: 7,601
    edited June 2006
    Aww...come on now!!!....You mean to tell me there ain't no tubes in that there rig???
    You NEED to get some tubes in the mix. The tubed pre made more difference in mine than any other upgrade I've done(excluding speakers).
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • amulford
    amulford Posts: 5,020
    edited June 2006
    Dude, you are a freak;)
    Give it a try. It does take off the edge. Kinda smooths things out...
    F1nut Posts: 51,764
    edited June 2006
    Dreaming about gear......yeah, you've got the disease.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2006
    Dreaming Pre amps..... :D
    What ever happen to a good old fashion "Wet Dream"?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    GRRRR! :mad: I'm kinda pissed at girls right now. :rolleyes:
    Wes
  • disneyjoe7
    edited June 2006
    Ya you can't think about yourself, you think about a TUBE???????????????????
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    If I upgrade the tweets, I'll certainly take an edge off, at least according to everone here.
    On the other hand, I certainly that I've finally gotten my system solidly into the upper third of mid-fi with the Rotel 1072 front end.
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    Okay, Freud. :)
    Wes
  • disneyjoe7
    edited June 2006
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • steveinaz
    steveinaz Posts: 19,545
    edited June 2006
    Wes
    Are you running the Rotel analog out or thru the DAC? You might try it on its own....
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    steveinaz wrote:
    Wes
    Right now, I have both hooked up. What I'm trying to do is listen to the Rotel on its own right now. Then swap to the Bel Canto and see what happens...
    Wes
  • steveinaz
    edited June 2006
    Cool, I'll bet that pup is sweet.
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    I think it is going to be pretty close in the end but it is still early.
    Wes
  • amulford
    edited June 2006
    Tubes take the harshness, if you will, out of an all sand system. Have you ever heard the analytical sound? Or the digital harshness of some CD's? Tubes will help out with that, kinda soften the edges...
    At least that's what I've found...
    And, yes, if you switch the tweeters, it will take off alot of edge, too.
    SCompRacer Posts: 9,112
    edited June 2006
    When I dream about changing tubes, it's more like this. A ring girl parades around with the tube number and....:D :cool:
  • disneyjoe7
    edited June 2006
    :eek: 7308 your count must be low. :D
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2006
    That's classic!!! :D
    Wes
  • organ
    organ Posts: 4,969
    edited June 2006
    ISIG,
    Funny, I had the exact same dream while waiting for my cdp. I remember having it sitting on my rack and I was searching for the best 12AU7. I guess we were thinking about audio gear before falling asleep:).
    SComp,
    ROTFLMFAO:D:D:D gotta love it when a pretty girl tells you to buy tubes;). Funny how she's telling you to buy "Siemens":D.
