Parasound 12V trigget hook up help?
GATOR3000
GATOR3000 Posts: 355
edited June 2006 in Electronics
The pic below is of Parasound HCA1500A 2x200 WPC amp. Above power cord socket right bottom area is the fuse and above the fuse is a 12V trigger. From the pic I see a couple of screws.
My question is: How do I connect to my B&K amp if I want to daisy chain the 2 amps to turn on? The B&K has RCA type connectors. Thanks.
Gator :):)
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
Post edited by GATOR3000 on
  • honestaquarian
    honestaquarian Posts: 3,243
    edited June 2006
    The twelve volt trigger is for a twelve volt INPUT on the parasound.It DOES NOT OUTPUT a twelve volt trigger signal.You would need to have that signal come from your pre/pro.Or a system controller like Crestron.Example-I am using the twelve volt trigger output on my Parasound AVC-2500 pre/pro to turn on my Monster Power HTS-2500 MKII power center.All of my amps are plugged into switched outlets on it.So when i turn the preamp on,it sends the twelve volt output signal to the power center and it turns on.It in turn, turns on all of my amps.
    Hope this helps!
  • GATOR3000
    edited June 2006
    Hope this helps!
    Honest,
    Thanks for your reply. I know what you mean. My B& K has in and out 12V trigger with RCA type connector. The Parasound has 2 screws. I guess I have to get a cable with one RCA end connector (out from B&K amp) and the other end of cable would be 2 bear wires (Parasound amp in 12v trigger). Is this right? As there is no particular connection plug on Parasound amp just 2 screws.
    Gator :):)
    Theatre System 5.1
    Original A8T CD
  • honestaquarian
    edited June 2006
    Gator
    Does the Denon have a twelve volt trigger output?If so does it have more than one?Can you put up a pic of the back of the Denon and the B&K?
  • GATOR3000
    edited June 2006
    Yes, I know can be done either way from Denon or B&K, but I run into the same problem......................one end of the cable mini-plug from Denon, or RCA from B&K, but what about the other end of cable going to Parasound. Two bear wires? I don't get it! Most amps have for 12V trigger either mini-plug or RCA, but never seen screws like the Parasound?
    Can anyone help?
    Gator
    Theatre System 5.1
    Original A8T CD
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2006
    Can you cut the B&K RCA cord so you can hook up the two under the same screw terminals? Two under each terminal think like cable in / cable out.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2006
    Hope this helps!
    Actually it does serve as a 12V relay, hence the external outputs. The 12V relay is 4 gang, ala monoblock configuration.
    If you're using said configuration, with a pre-amp trigger, to trigger your surge protection...aren't you defeating the purpose of surge protection? The Monster unit should be the trigger, or deciding unit for turn on...otherwise you defeat the purpose.
  • honestaquarian
    edited June 2006
    The preamp is plugged into an unswitched outlet on the back of the Monster.It along with the entire stereo is plugged into the Monster,so it is all protected.
  • honestaquarian
    edited June 2006
    Can anyone help?
    Gator
    Actually to be honest with you i have ONLY seen twelve volt triggers in the form of 1/8 mini plug or the screw terminals.I have no recollection of EVER having seen a twelve volt trigger in the form of an RCA jack.
  • GATOR3000
    edited June 2006
    I guess cutting one end of the 12V trigger cable is the only way to go.
    Theatre System 5.1
    Original A8T CD
  • dorokusai
    edited June 2006
    Ok, just wondering.
