Parallel Wiring 2 Centers
wingnut4772
wingnut4772 Posts: 7,519
It was suggested to me to parallel wire my VSA LCR15 center with another and just have two centers. The guy that told me this sells and installs them and said that the speaker was 12 ohm and it would be fine but I am not seeing this. Does anyone think this is ok? These are the LCR15 Center Specs . I don't see anything that says 12 ohm here. What am I missing?
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • Skynut
    Skynut Posts: 2,967
    edited June 2006
    I split my center pre/out signal to run three center speakers.
    I do not know about running them in series but mine sounds fine with three amps running them.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • wingnut4772
    edited June 2006
    This guy was just suggesting that I run the two centers on the same amp channel and just use two cables....?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • unc2701
    unc2701 Posts: 3,587
    edited June 2006
    The speaker specs say 8 ohm nominal, 7 ohm min. That means in parallel, you'll get 4 ohm nom, 3.5 ohm min- which should be fine on the cinenova.
    If the result sounds a little funky to you, you're probably experiencing comb filtering. In my experience most rooms have so much reflected sound that it doesn't matter, but every room is different.
    Backburner:Krell KAV-300i
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited June 2006
    What is the expected benifit if you run it off the same amp channel? Were you planning on stacking them? Couldn't you just bump up the dbs on the processor? Just curious.
    Darla I thought that you were very happy with the center?
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • unc2701
    edited June 2006
    There's no benefit to running off the same amp channel... but if you're out of free channels, then there's no problem with running it on the same channel.
    The benefit of dual centers is that with over/under placement and good vertical "toe in" the sound imaging sounds more like it's coming right from the center of the TV screen. The drawback is that in some rooms you'll get comb filtering- kinda like bass nulls, but at many frequencies. However, if the center channels are equidistant to the primary listening position, I find this effect is pretty minimal... but some people disagree.
  • Midnite Mick
    edited June 2006
    I have never thought of that...Thanks
    Mike
    Consonance cd120T
    Usher CP 6311
  • unc2701
    edited June 2006
    The one other benefit is if you've got a big room and can't get enough volume from one center without compression. However, you're usually better off dumping the one you've got and moving up to a higher model, but that's not an option here.
