Center Channel -- Traditional vs. Single Bookshelf
I know some of you guys have used a single bookshelf speaker as a center channel instead of a traditional center channel speaker. Generally, what is the difference in SQ?
I am contemplating a change in my center channel (currently using an Ed Frias modded BIC DV-62CLRS) and was wondering what the pros and cons were of using a single bookshelf speaker. Room size is 13 x 20 x 8.
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I used an LSI9 as a center compared to the dedicated LSIC center ONLY because I was really disappointed with the LSIC. Generally speaking I think a dedicated center is a good way to go. That's what I have now.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
I had tried both Lsi9 and LsiC for my HT but eventually kept LsiC due to more wide sound dispersion than Lsi9.
Lsi9 was good if you are in sweet spot but if you are off axis then it doesn't sound as good compared to LsiC.
I would have choosen Lsi9 if i was the only one watching movie in the sweet spot but that wasn't the case with me.
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
OK, thanks for the responses.
I can probably get away with a bookshelf speaker because 99% of the time it's just my wife and me watching a movie, and we sit directly in front of the TV/center channel.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early B. wrote:OK, thanks for the responses.
I can probably get away with a bookshelf speaker because 99% of the time it's just my wife and me watching a movie, and we sit directly in front of the TV/center channel. -
I was experimenting with the use of a bookshelf speaker today as a center channel and decided that a center channel is better. They both sound good, but the center channel speaker provides lots more soundstage, even when sitting on axis.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I run two CSi40's above and below my Sony 34" TV, and really like the impact. I also experimented with using a pair of RTi38's below the TV, splitting the center channel pre-out into the right/left channels of a 2 ch power amp. If it had not been for the challenge of getting the RTi38's to fit I would of went with this setup. You can then angle the two bookshelves out slightly and you really fill a room with the center channel dialogue.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I'm also loosely considering using a pair of bookshelf speakers (at least temporarily) in lieu of a center channel speaker. I don't have a separate amp, so the only way I can hook both of the bookshelf speakers up is by sharing the center channel binding post on the receiver (one speaker using spades and the other using bananas). Will this work?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Early B. wrote:I was experimenting with the use of a bookshelf speaker today as a center channel and decided that a center channel is better. They both sound good, but the center channel speaker provides lots more soundstage, even when sitting on axis.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
tryrrthg wrote:When doing this did you have the bookshelf mounted vertically (like it should be) or horizontally. just curious...
Good point. Had it vertical for the demo. I'm sure I could play around with placement and the receiver's settings to make the bookshelf sound better, but eventually I'd probably end up with another center channel.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I am going to try another center also but I am limited to putting them above the TV because it is a pedestal style DLP. I am just going to have 1 big row and see how it sounds.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
wingnut4772 wrote:I am just going to have 1 big row and see how it sounds.
Ooohhhh. That's sounds interesting. Please let us know how it works!!
Add pics, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Are there certain bookshelfs that functions well singly as a center? It was suggested to me that I use my RT55i single speaker (I only have one which I bought off of ebay) as a center. If I were to do that which mains will match up well?
jldude wrote:Are there certain bookshelfs that functions well singly as a center? It was suggested to me that I use my RT55i single speaker (I only have one which I bought off of ebay) as a center. If I were to do that which mains will match up well?
