Yet another Cherokee Install...
Gene 5301
Gene 5301 Posts: 4
edited June 2006 in Car Audio & Electronics
I have a 3000 Cherokee Classic. I have upgraded the factory head unit to an Alpine CDA9856. A 10" J-L Audio subwoofer has been installed in the rear cubby hole in a custom fiferglass enclosure. A 220 watt Alpine amp for the sub has been installed under the rear seat. The speakers in the soundbar have been upgraded to the MMC525's. The clarity and depth are great. I bought another set for the front doors, but they are too small. Will MMC650's fit in the doors? Thanks in advance.
Post edited by Gene 5301 on
  • Greg Peters
    Greg Peters Posts: 605
    edited June 2006
    That's a 2000 Cherokee?
    I would bet the tweeters on the mmc650s stick out too far to mount in the front door factory locations without cutting out the plastic grill from the door panel. The mmc6500s would probably do if you mounted the seperate tweeter from the component set on the sail panels or in the A pillers. 6 1/2 inch speakers should drop right into the front doors (if you remove the factory spash guard and drill new mounting holes).
  • tigmd99
    tigmd99 Posts: 50
    edited June 2006
    Oh no, you have a JL Audio product...beware of the bias crap from the members of this forum!! Read this thread to learn more about the "gurus" of this forum:
    http://www.polkaudio.com/forums/showthread.php?t=41315
    Good luck.
    VR3 Posts: 29,522
    edited June 2006
    The amount of stupidity raging from your pores is astounding.
    Please proceed to kick yourself in the nuts.
  • tigmd99
    tigmd99 Posts: 50
    edited June 2006
    You should not talk to Greg or Gene like that. What have they done to you?! Geez. It kinda makes you look like an **** yourself by insulting people like that.
    Be nice to people. Life is too short.:)
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited June 2006
    Good luck.
    Now you are just going around and looking for problems.... why? If you do not like it here why hang around. I am frankly getting tired of your insults that are geared towards everyone here. I am part of this forum and responded to your other thread. Not once did I insult you, but you insulted all of us, that includes me.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2006
    Dont feed the troll! Cody has the right idea, ignore list baby!
  • 1996blackmax
    edited June 2006
    Sounds good to me Mac.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Greg Peters
    edited June 2006
    Apologies- someone tried to hijack your thread to make a point.
    Some off-topic comments are not directed at you, Gene 5301, so please disregard them.
  • Bran
    Bran Posts: 8
    edited June 2006
    Hey Gene,
    I dont know if you did anything yet but are those tweeters bigger than the db model? I have a 98 cherokee sport and installed 6.5's in the rear sound bar and 6.5 components in the front door also. The tweeters would never have fit in the stock window bar?? I cut off the original speaker grill off the body molding and then bonded the tweeter holder to the original molding...If you are careful it all fits fine, and looks great:D Sounds really good too, since they are being ran off an amp. From the little I read, it looks like those MM or whatever are even better. Hope that helps,
    Brandon
  • audiobliss
    audiobliss Posts: 12,518
    edited June 2006
    Bran - Could you post some pics of the way you have the grills done for your front speakers? I'd be interested in seeing that...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
