watts on the rotel 985
jabrax
jabrax Posts: 315
edited June 2006 in Electronics
I cant find any information on the Rotel RB985's ability to run 4ohm and at what wattage...it has 5ch at 100 for 8ohm.
Any one have this thing?
TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII
Post edited by jabrax on
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2006
    SCompRacer Posts: 9,112
    edited June 2006
    I've got a RB 985MKII powering some Polk LC-265i/LC65i in-walls (think Lsi9/Lsi7's) and it does a great job. They just list wattage specs for 8 Ohms with a minimum speaker impedance of 4 ohms. I would estimate around 160 WPC for 4 Ohms.
  • jabrax
    jabrax Posts: 315
    edited June 2006
    See below.....What the heck is DIN? Does this mean 220 4ohm?
    Continuous Power Output 100 watts/ch (20-20kHz 8 ohms, < 0.03% THD)
    DIN Output 220 watts/ch (1 kHz 4 ohms, 1% THD)
    Total Harmonic Distortion (20Hz - 20,000Hz) < 0.03%
    Intermodulation Distortion (60Hz : 7kHz, 4:1) < 0.03%
    Frequency Response 10 - 80,000 Hz, +/- 0.5 dB
    Peak Current Output (.1 Ohm load, 10 ms, 1 pulse) 40 Amps
    Damping Factor (20 - 20,000 Hz, 8 Ohms) 180
    Speaker Impedance 4 Ohm minumum
    Signal to Noise Ratio (IHF A network) 115 dB
    Power Amplifer Input Iimpedance 27 K Ohms
    Power Requirements
    115 Volts, 60 Hz or
    230 Volts, 50 Hz
    Power Consumption Max 800 Watts
    Center - Polk LSIC
    Sub - DSWPRO600
    Blue Ray - PS3
    F1nut Posts: 51,786
    edited June 2006
    DIN (Deutsche Industrie Normen) is a German spec standard. In this case it's for measuring peak power.
  • jabrax
    jabrax Posts: 315
    edited June 2006
    Thx for the info, this just doesnt get easy.......330 watt 2ch or 100+something 5 channel for lsi9s hmmmmmm.....damit, i am buying one or the other before tomorrow is over...
    Guess I will decide by when i open my eyes in the morning
    Center - Polk LSIC
    Sub - DSWPRO600
    Blue Ray - PS3
  • cheddar
    cheddar Posts: 2,390
    edited June 2006
    I would always go with the most amplification on the LSI speakers that are hardest to drive. That's the mains first and then the center. Unless you plan on not upgrading in the future, there is a difference in being able to drive the LSIs and getting the best quality sound out of them. And the sound quality really improves with a lot of power. And it gives you good upgrade paths in the future to add good amplification to your surrounds. But right now, both music and movies use the surrounds a lot less than the front stage, especially the mains.
  • cheddar
    edited June 2006
    1%THD? I wonder what the THD maxes out at across the whole spectrum?
  • unc2701
    unc2701 Posts: 3,587
    edited June 2006
    probably 2-4% at 20K, and a little lower different at 500, 100.
    Backburner:Krell KAV-300i
  • jabrax
    jabrax Posts: 315
    edited June 2006
    Upgrade in the future is definately gonna happen...Moving soon, so keeping the cash flow in check until its settled...Then look for mass sale and upgrades within the year....But need something now, quality of sound at low volume is killing me lol
    Center - Polk LSIC
    Sub - DSWPRO600
    Blue Ray - PS3
  • cheddar
    edited June 2006
    This doesn't inspire confidence in the amp, especially driving it hard with a speaker impedance that will drop below 4 ohms. You really might want to go for better 2 channel amplification.
  • unc2701
    edited June 2006
    Those numbers a a direct function of the fact that they're specing it at DIN. At around 160 watts, it'd be <0.05 %THD. Think of the 220 watts as a "sony spec".
    THD only really tells you how hard they're driving the amp to get the wattage rating they're quoting- while there are better amps out there, that spec isn't a reason not to buy the rotel.
  • cheddar
    edited June 2006
    DIN, so they're just trying to make like it's a 220W amp. But not really. That makes sense, thanks. For the limited price range he's looking at, I'd still put the money into a quality two channel amp, though. Seems like he might have better choices than to try and spread it over his surrounds too.
    F1nut Posts: 51,786
    edited June 2006
    Actually, the DIN specs are suppose to be a more accurate measurement than anything else.
  • unc2701
    edited June 2006
    I agree completely- they're very specific and kinda reveal how stupid the specs are for things marketed in the US.... if everyone used DIN, then we wouldn't have the "sony spec" phenomenon.
    My only problem with DIN is that they're written more with device failure (as in meltdown) in mind rather than quality sound.
