Warm glow to tubes...
Wardsweb
Wardsweb Posts: 942
edited June 2006 in Electronics
saweet!
Post edited by Wardsweb on
    F1nut Posts: 51,778
    edited June 2006
    Nice pic!
  • Schris22
    Schris22 Posts: 983
    edited June 2006
    purty lights!
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2006
    I feel warm already...
    I wish I had the pic when I over-biased a tube prior to resale, 9 hours away.
    The screwdriver slipped off the pot, in mid adjustment, and before I could correct it....RED HOT>>>POW. Some of you may know what I mean, and it sucks when it happens to original tubes....in OG monoblocks.
    Manley LAB100 Monoblocks - $1500
    Replacement EL34 - $98
    Suggestion by original buyer, after explanation, of $500 for the pair...so he can repair them if needed? - Priceless
    They have since been re-tubed(JJ/Tesla), re-biased and boxed up for another gig.
    F1nut Posts: 51,778
    edited June 2006
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
  • madmax
    madmax Posts: 12,434
    edited June 2006
    dorokusai wrote:
    Priceless
    definition: priceless...
    The act of re-biasing a tube amp days after a previous biasing which included a quick bias at warmup, another bias after 1 hour, another check and tweak after 2 hours of playing music and another sanity check after sitting idle for another 5 hours and then having a screw driver slip. :D
    madmax
    Vinyl, the final frontier...
  • faster100
    faster100 Posts: 6,124
    edited June 2006
    Tube magic :D
    same thing happens when you select the wrong voltage on a tube tester.. i popped a few worthless tv tubes for fun, crank up the voltage till you get the bright flash and then dead :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
