digital and rca cables
pmckeealaska
pmckeealaska Posts: 808
edited May 2006 in Electronics
OK....so I have a system that I use for both 2 channel and HT. I also enjoy listening to high rez (DVD-A, SACD), so I have all the cables I need for that. My question is, and this may be a stupid question, do I need a digital optical cable for any reason? The sales guy at a store told me I needed it for HT listening. One cable instead of the five that I already have for high rez. I picked up a $15.00 digital cable just in case. Please helped this confused member!
Music and Movie Rig
Samsung 40" HDTV 1080p
LSi25 Front Speakers
LSiC Center Channel
LSiFX Surrounds
Rotel RB 1080 2-Channel Amp
NAD T763 Reciever
Denon DVD 2900 Universal Player
Audiosource 10 Band Digital Equalizer
Audioquest CV-8 speaker cables
Audioquest Sub-X subwoofer cables
Audioquest King Cobra Interconnects
Monster AVS 2000 Voltage Stabilizer
Playstation 3 120GB Slim
Post edited by pmckeealaska on
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2006
    The high-rez stuff has to go through the analog outs.
  • pmckeealaska
    edited May 2006
    I know I need the rca's for high rez, but do I need the digital cable for HT??
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
  • polkatese
    polkatese Posts: 6,767
    edited May 2006
    yes, for DD and DTS contents of your movies and music videos.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    tonyb Posts: 33,072
    edited May 2006
    Don't know much about NAD receivers,if you have all your analog pre-outs
    l-r-c-rs-ls-sub hooked up and you have it set up that way on your dvd player
    then you should be OK.I have a digital cable also with my rig and when I switch from 2-channel to movies,my dvd player will recognize it and picks
    up the DD SIGNAL thru my digital cable.So the answer is it won't hurt anything,hook them both up,go into your set-up menu and make sure
    DD is turned on,see if it makes a difference,if not take the cable back and buy a good CD.Just for **** and grins,how do you have the subs on the
    LSI's hooked up?:)
  • pmckeealaska
    edited May 2006
    The NAD has 2 subwoofer outs. I have my Sub-X cables running from the LFE in to the subwwofer outs on the reciever. The cables make a noticable difference compared to going without them.
    Music and Movie Rig
    LSiC Center Channel
    LSiFX Surrounds
    NAD T763 Reciever
    tonyb Posts: 33,072
    edited May 2006
    Well of coarse they do,especially when watching movies,but how is that
    for music?Do you have everything set up in your receiver correctly?Some of the most common problems is the built in subs throw people off when trying to set up a HT.Well,I am getting of the subject here,you still can use both cables,when you play a movie,see in the dvd display if it says DD.Does it say
    that without a digital cable hooked up?
    I leave both hooked up on mine.
  • ledhed
    ledhed Posts: 1,088
    edited May 2006
    I believe it all has to do with which unit is doing the processing. If it is the DVD player then your analog ICs should be fine. If it is the avr then you need a digital connection.
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Bingo, i think we have a winner.
    I had my sacd player hooked up this way and I like the processing in the avr better for movies. Sacd would only play through analog.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • janmike
    janmike Posts: 6,146
    edited May 2006
    Exactly, where does the best DAC reside.
    Michael ;)
    NORTH of 60°
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    There should be one in your receiver and one in your DVD/CD player. If you use digital IC cables then you are using the DAC in the receiver. If you are using analog cables then you are using the DAC in the DVD/CD player. So if you have a bitchen CD player then use analog cables to hear the best quality. Other wise Digital is just fine until you get about $4000 or more into youre setup.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
