help me choose the best sub for the $
hexon
I am willing to put out $200 dollars for a sub. I already know what amp I will be getting. It is the Profile AP1200 (http://www.crutchfield.com/S-1jYCAbXBCKw/cgi-bin/prodview.asp?i=489AP1200&s=0&cc=01). This amp is a two channel amp that is 200wattsx2 @4ohms. Bridged it can do 600 watts x1 @4ohms. I was looking into getting the Polk MM 2124 or the Kicker Comp VR 05CVR122. This 12" kicker sub is a dual 2ohm sub which would work with my amp.
I really need to know which is the best sub for me. I want really loud bass that has good clarity and precision, too. Help me!
If you know of a better sub, please tell me what it is.
SHIFT_LOUD
polkaudio db675
polkaudio db212-2
Kenwood KAC-9102D 500 watts @ 4 ohms (850 watts @ 2 ohms)
Sony 444watt amp
polkaudio db675
polkaudio db212-2
Sony 444watt amp
Post edited by hexon on
The 2124 is the better sub but be careful with the gains and volume as 600 is a little much for that 12.polkaudio sound quality competitor since 2005
At that price range you could be looking at a Soundsplinter RL-p12. It is a little more, but that sub is in a totally higher league than the subs you mentioned, plus it can take the full power of that amp all day long.
http://soundsplinter.com/rlp_premium_series_12_and_15_inch_subwoofer.html
http://www.soundsplinter.com/rlp12_premium_series_12_inch_DIY_subwoofer_information.htmlAlpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
hexon wrote:If I turn down the power going to the sub to about 2/3 giving it 400 watts, would it be okay to mess around with the gain a little more?
Huh?polkaudio sound quality competitor since 2005
hexon wrote:Where could I find the soundsplinter subs for the cheapest price? and what type of bass could I expect from them compared to the momo 12
You could find the sub through the links I provided. Like I said, when you move up to that sub you are in a whole other league. The SS will get substantially louder and still be able to play very clean bass.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
I have changed my mind. I am going with the polk db212-2 and a kenwood amp that has 800watts @ 2ohms. This should have massive bass. I have heard them in cars at school and they give you headaches as they pass by you : ).
If that is what you are after......
Just remember to practice safe volume levels for you ears.
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
