speaker stand quesiton
Home Theatre
Home Theatre Posts: 469
edited June 2006 in Speakers
I just bought the Euro version of the Monitor 30. Great speaker. I bought two speakers stands that our 16 inches each. They look funny up against my big screen. Here is my question my system sounds great. If i go with 24 or 31 inch stands are the rear speakers still going to match up with the fronts as well. Right now the rear speakers are at 15 inches and the fronts are at 16 inches. Sorry if this is a stupid question.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
  • Early B.
    Early B. Posts: 7,900
    edited May 2006
    Actually, your rear speakers should be 5 or 6 feet high, if possible. If not, use tall stands for them. For the fronts, the stands should be low or high, depending upon whether they place the tweeter at ear level.
    "God grooves with tubes."
  • Refefer
    Refefer Posts: 1,280
    edited May 2006
    +1
    Try to have the tweeters on your fronts at ear level when you're sitting in your favorite chair.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • peteran
    peteran Posts: 141
    edited May 2006
    the rear speakers should be at least 2-3 feet higher than your ear level.
  • janmike
    janmike Posts: 6,146
    edited May 2006
    That is something I did not know. I guess I assumed that both the front and rear speakers should all be at ear level.
    Michael ;)
    NORTH of 60°
  • AzN_plyR
    AzN_plyR Posts: 96
    edited May 2006
    why do they have to be so high up.... mines are only almost 1 feet higher....
  • Early B.
    edited May 2006
    The rear speakers provide diffused, ambient sounds. If they are at ear level, you are less likely to experience the full effect of this diffused sound. Imagine the sound of a jet or an explosion being heard directly at ear level or coming at you indirectly (i.e., from 3 ft. higher than ear level). The sound would be different, right? Now, of course, with the center channel and front speakers you want them to be at ear level because they provide the dialogue and other critical sounds that should be heard directly.
  • critical_gp
    critical_gp Posts: 84
    edited June 2006
    Wow, I did not know that...i have my r30s at ear level when sitting. How do I up-lift them? Custom 1' stand? Project!
    Audio system lost to water damage... :(
  • Home Theatre
    edited June 2006
    Ok here is my deal. My rears are at 16 inches sitting on two end tables, on both sides on a couch. What height would you have the fronts. They are sitting at about 16 right now. I am going to built my own stands cause the other ones are not cutting it. I bought them at circuit city built them,
    thought they were at the right height. I threw away the box, so I cant return them. Any help would be great.
