Gainclone done the Wardsweb way
Wardsweb
My latest project started almost two years ago. Things got busy, life got in the way and the project was shelved back in 2004. Well yesterday I pulled the parts out and decided to whip this thing out for next weeks audio meet in Austin.
Here is a page I've started on the builtd: Wardsweb Gainclone (WWGC)
Post edited by Wardsweb on
Very cool. Are you going to put some LED's inside it to get the cool glow like your Champion II?
What kind of specs will it have? How does the heat get transfered mto the sinks? Did you do the circuit design?
I love to build things, but my expertise is in a different realm... -
No plans for lights at the moment, but you never know. The LM3875 chip is rated at 56 watts into 8 ohms, so this is basically a 100 watt amplifier. Building is easy, as you just stuff the boards, add a transformer and chassis. That's basically how it goes. The boards came from BrianGT over at the diyaudio forums.
Done
very clean looking.
how is the heat transferred? -
I was pushing it pretty hard last night just to see and it doesn't even get warm. The heat sinks are WAY overkill, but they look cool and make for nice sides to the amp.amulford wrote:very clean looking.
Such talent we have here! Looks cool.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Very impressive!
Would this amp be a common ground for use with SDA's?
HBomb***WAREMTAE*** -
Looks good, Luther.Political Correctness'.........defined
