Question about the original sunfire 200x5...
confused1234
Does anyone have an opinion on the original Sunfire 200x5 amplifier? From what I can gather it was released in 1997. I am thinking of buying one used but I am not sure of the specs and also if it is worth the $1000 price tag?
TV - Pioneer Elite 1130HD
DVD - Pioneer Elite DV-79AVi
Receiver/Preamp: - Pioneer Elite VSX-72TXV
Finally an Amp: - Sunfire Cinema Grand 200~5
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Cables: Blue Jeans Cables
NOW :eek: Gotta find a suuuuubwoofer!!:eek:
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Post edited by confused1234 on
I have never heard the amp but I have th preamp and it is very well built and sounds way better than the Onkyo TX-DS 787 it replaced.
Don't know if that helps but...Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
nearly everything about sunfire is a very good thing. Thats my personal opinion on the brand. All the sunfire gear is very powerful stuff.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
I head there was some problems with some of their older models with transformer buzzing, but i think they fixed that. Might want to do find the serial number from the person you are buying from and give sunfire a call. They should be able to tell you more info about any particular serial number.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
