Amp for RTi8's
jhermance
jhermance Posts: 214
edited May 2006 in Speakers
I am looking for an amp for the set of rti8's i just picked up. Keep in mind i will be eventually upgrading to a set of rti12's.
Thanks in advance for the help guys.
Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza™ Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects
Post edited by jhermance on
  • marcpam
    marcpam Posts: 228
    edited May 2006
    Check out the Outlaw 7700 or 7500. 200 watts/channel into 8 ohm and 300 watts/channel into 4 ohm
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2006
    Outlaw, Parasound, Rotel, Adcom, etc. etc. the list is endless. Do a search on amplifiers here on the forum & read up!!! Try not to settle for less that 200 wpc especially if you plan to upgrade to larger speakers.
  • EricBurg
    EricBurg Posts: 64
    edited May 2006
    i have a Rotel 1080 powering a pair of Rti10's and am very happy with that combo. The rest of my system is powered by Rotel 1075. I am using a pioneer 1015 as a pre/pro for now. I like the way the system sounds.
    All the amps that have been listed are all capable and will get you nice results. I agree that you will want 200 wpc at a minimum if you plan to upgrade to the Rti10's or 12's.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
  • MattN03
    MattN03 Posts: 558
    edited May 2006
    Anyone try using a B & K amp with RTi's?
