BFD Question?
gacole2000
I have seen a lot of info on the BFD 1124, but see many 1100 on the bay for pretty cheap. I am wanting to tame my sub curve and wondered if the cheaper version would work for my needs. Any experiences are appreciated!
AVR: Yamaha RX-V661
DVD: Yamaha DV-C6480
BR: Samsung 1600
Mains: Polk RT55 (bi-amped)
Center: CS300
Sides: FX1000
Rears: RT/FX
Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
Projector: Optoma HD70 w/ 106" Elite Screen
Power: Panamax MAX 5100
Remote: Harmony One
BR: Samsung 1600
Center: CS300
Sides: FX1000
Rears: RT/FX
Remote: Harmony One
Post edited by gacole2000 on
I believe the difference is the 1100 uses 20 bit dacs and the 1124 uses 24 bit. For a sub, either should work for you.
