SDA cable question
Jack Dawson
I have 1.2tl's without the SDA cable. How do I wire them up with regular speaker wire?
Thanks,
Jack
Thanks,
Jack
Post edited by Jack Dawson on
A single wire, even a hanger will work from round SDA pin hole on one speaker to the same hole on the other speaker. This connection is the only connection needed to make the SDA circuit complete on the latest SDA models like your 1.2tls.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Wait a sec, I thought you had a problem with your AVR shutting down when the cable was connected and now you say you don't have the cable???Political Correctness'.........defined
