I need sub box plans!
sc0tty8
I need sub box plans. I need plans for the momo 12's. I want some nice, deep bass. I was thinkning of a box at about 1.25-1.5cu per sub as I have been experimenting with my prefab box stuffing poly fill in it. I found that with the 1.2 per sub with about 1/2 a pound if that of fill sounds most excellent in my car. I want to build a box so I can run bolts thru it and bolt it in. the prefab box goes to the other car....
I need the box to fit up against a back seat, I have about 36-38" wide to work with, up to 16" high, and as deep as ya want. A box to fit in between the fenders would be sweet. I am hoping that Justin can help me out here.....
I got plans for a iso-baric setup for a pair of the DX series, and they are still going strong.
Please and thanks?
Scott
Please and thanks?
Scott
Post edited by sc0tty8 on
Gee, thanks:rolleyes:
You're in the Home Stereo/Theater section, so it's no surprise that you didn't get any help. Go to one of the car audio sections (under "On the Move").
Aaron -
u need a bigger box than 1.5 sealed for the momos.i got gnx 12 n 1.6 per with 25 cubes of port.design a bigger box.
Design me one then. I am dumb when it comes to making the sub box plans:(
