Huge Problem!
limashaynut
Okay, I admit it is more like a minor inconvenience or aggravation:p .
I have a Denon AVR 3806 that I have had since November 2005, and overall I have been very happy with it, but as of late there has been a glitch that has come up that has got on my last nerve.
The front panel door (under the display) now will not stay fully closed. When new this panel would close flush with the front of the unit, but now will sag (for lack of a better word) ajar after it is full closed. Think car door slightly ajar.
It did not used to do this, and it has been opened and closed very little since I first got it new, this is mostly due to the fact that you can adjust almost all of the features with the remote and the on screen programing. Everything looks just fine with the hinges on the bottom of the door, and nothing seems to be broken. While the top of the door is flush when you close it, it then gaps slightly (maybe 1/8") when you take your hand away. This kind of ruins the clean look to the front of the AVR, and damn it, it irks me!
Has anyone else had this problem, and is there an easy fix? I would really hate to ship it off to have this stupid little annoyance fixed.
Jerry
Denon AVR-3806 7.1
Outlaw Audio M200 (RF,C,LF)
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
Polk PSW505 sw (I know, I know, get an SVS!)
PLUCK THE CHICKS!
From A Former Fan
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan
Post edited by limashaynut on
i don't know about a fix. but a temp solution might be to get those little round dots of velcro and mount one on the door and one on the Denon. and it will stay closed then. and you wouldn't be able to see it either. when the door is closed.
just a weird solution to an annoying problemPolkFest 2012, who's going>?
I thought about that, but I do not beleive there is enough clearance between the back of the door and the face of the AVR to make that work. While the velcro would hold it in place, the thickness of the velcro would cause the door to stick out just as far as it is now if not farther. I am going to try that anyway next time I stop into Home Deopt and pick some up, but I do not think that will work. The other thing I am going to try is to get some of the tiny felt pads that you put on the bottom of things to keep them from scratching furniture. I would put one on the side of the opening (between the top side edge of the door and the side of the door opening) to see if this will add just enough friction to keep it closed. Thanks for the idea.Jerry
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan -
well something had to happen to cause it to be off kilter like that so it doesn't work properly now.
good luck. I think a call to a Denon repair shop might be in your future. maybe it's covered under their warranty?PolkFest 2012, who's going>?
Throw it in the trash.
*REMINDER TO SELF.......FIND OUT LIMA'S TRASH PICK-UP DAY*"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Duct Tape work wonders.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Trash pick up is on Tuesdays, it will be the piece with duct tape on the front!Jerry
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan -
Is there some sort of latch or does it set into place freely?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
NO, if you look at the picture closely, you can see that all of the locking features are built into the hinges themselves. The top of the opening simply has a couple of little tiny pads for the door to rest on.Jerry
Denon AVR-3806 7.1
Sony KDFE42A10 LCD
Directv H10-250 DVR
Sony DVP-NS90V
Sony RDR-GX315
JVC Super VHS
Polk RTi8 m
Polk CSi5 c
Polk RTi6 sr
Polk Monitor 30 srb
PLUCK THE CHICKS!
From A Former Fan -
Isn't it still under warranty?"SOME PEOPLE CALL ME MAURICE,
One word.......EPOXYHarman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
I read reviews about the same thing happening to the HK 635, but purchased one anyway. Most people used tape (clear, no duct) or velcro as advised in earlier post to resolve the problem.
For fear or it, I actually still have the tape that came on the sides of my HK 635 front panel. . . just in case. Silly that $1200 MSRP AVRs can have QC issues like that, but, oh well.
Good luck!Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
AndyGwis wrote:I read reviews about the same thing happening to the HK 635, but purchased one anyway. Most people used tape (clear, no duct) or velcro as advised in earlier post to resolve the problem.
Good luck!
I have the same problem and used the same fix as you (kept the tape that came with it) works fine considering how often you really need to open that panel. It's not worth it to me to even consider unhooking, boxing up, sending back, hooking up my old JVC in the meantime, unhooking the JVC, Unpacking the HK, hooking up the HK....just to have the door fixed.
At $1200 MSRP you sure would expect it to work perfect. Maybe this just means they put so much effort into the rest of it they didn't have time to worry about the flipdown cover........right.....HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
I had a boombox cd player that would not stay shut and I found a small piece of dirt was in the way of the clasp so it could not click shut. I blew it out with air and now it works again.
Tape will leave a residue but the vinyl (i think its vinyl) they use should come off without an issue.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
