Is it possible..?
beardog03
beardog03 Posts: 5,550
edited May 2006 in 2 Channel Audio
Is it possible to magnetize a cd..?
I`m getting problems and static...even clipping from the right side
I tried 2 complete different systems....still the right side speaker is barely playing and causing problems....:mad:
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited May 2006
    Hi Robert,
    Doubtful. To my knowledge, there is nothing to magnetize in the media. I'd be looking for a tube going bad somewhere in the signal path.
    Ooops, just re-read. With two separate systems, it's a mystery. CD dirty? Did it play well in the past?
  • beardog03
    edited May 2006
    Hey Blue..!
    How are ya doin bro..?
    Ya, my first thought was a bad tube also..
    I cleaned the cd, and about to try it in yet a third completely different system..!
    Sometimes multiple sytems are a good thing..!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    dorokusai Posts: 25,577
    edited May 2006
    A CD cannot be magnetized....stop talking to the leprechauns.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2006
    Sounds like something is wrong with the right side of your CD.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Turn it around and see if the problem goes to the left speaker.:confused:
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • steveinaz
    steveinaz Posts: 19,538
    edited May 2006
    That's strange---only that particular CD?
  • ND13
    ND13 Posts: 7,601
    edited May 2006
    Bear,
    Are you sure it's not the medication????;) :D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2006
    Is this CD a store bought or a copy version? If a store version maybe your pre amp, amp or speaker is given you trouble.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    heiney9 Posts: 25,203
    edited May 2006
    It's a rare phenomenon but it could be the layer with the 1's and 0's has become defective in certain spots. Hold it up to the light and look for pin holes or discoloration. I've never had this happen with a store bought cd, but I've had 2 out of about 500+ cdr's with this phenomenon. Just a thought.
  • beardog03
    edited May 2006
    now I can`t get it to eject outta the VCR...wtf
    I put it in the all SS sytem and it plays fine...like blue said...must be a bad tube somewhere in the mix
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2006
    Rewind the cd all the way, then try it.
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2006
    As per Doro's recent suggestion for myself, I'd try putting the right channel IC in your right ear, and seeing if that helps any.
    If not, you may wanna make sure the little 'security' tab on the front hasn't been broken off.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
    edited May 2006
    Didn't know they made tube vcr's.......;)
  • Refefer
    Refefer Posts: 1,280
    edited May 2006
    Interestingly enough, I once bought a special edition cd from a garage band I know that used engraved metal as the actual cd cover. A very small layer, but a layer never the less. In my friends less than ideal setup, the cd would skip horribly due to it's vacinity to his home made sub woofer, I assume due to the magnetic forces.
    I doubt anyone else has done this as the process is also obscenely expensive.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    mhardy6647 Posts: 33,957
    edited May 2006
    mmmm... the data layer on manufactured CD's is aluminum, which is resolutely non-magnetic. They make voice-coils out of aluminum wire.
    Now, aluminum CAN oxidize, but I don't thinkyou have a problem with your medium.
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2006
    You guys obviously are not true audiophiles. I can fix it for $325.
    http://www.gcaudio.com/cgi-bin/store/showProduct.cgi?id=190
  • organ
    organ Posts: 4,969
    edited May 2006
    Waaaaaaa:eek: . I have an XLO cd with a "Demagnetizing Sweep" track. If anyone is interested, I'll sell for $200 shipped. No use in just demagnetizing the cd, you have to demagnetize your whole rig:p ;) .
