In-wall Sub
Lowell_M
Lowell_M Posts: 1,660
edited May 2006 in Speakers
I am building a home theater in my basement and building the TV and components flush with a wall for a clean, theater screen look. My wife isn't too excited about the big Velodyne cabinet, but could probably be convinced to use it as an endtable or something. She did ask a question that I didn't have an answer for though.....
Could I build the sub into the wall so the front of the cabinet is flush with the front wall beside the TV? Would there be any issues other than the lack of flexibilty in sub placement if this position isn't right for the room?
:confused::confused::confused:
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • tryrrthg
    tryrrthg Posts: 1,896
    edited May 2006
    Check out an infinite baffle sub
  • Lowell_M
    edited May 2006
    I didn't read the entire page, but I already have a sub. I don't (and can't right now) want to replace my sub. I just want to know if I can mount it in the wall. Should I keep reading that link for an answer?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • unc2701
    unc2701 Posts: 3,587
    edited May 2006
    assuming the port & speaker are at the front, it will be an ok, but less than ideal solution. If you make it fit tight, you won't be able to get to the electronics or put in a different sub in the future. If you make it big, you'll get weird gain/ boominess from the enclosure around the sub. One option would be to take apart your sub and recreate it in MDF in the wall, but with the electronics, port and driver all accessible. That would give you the cleanest solution (but would leave you stuck with that sub).
    You could also take apart your sub and switch it over to an IB, but given that it's ported now, you'll probably bottom it out trying to get to the levels you were reaching before. It'll go below the driver Fs with much more authority, but everywhere else you'll have less volume.
    Backburner:Krell KAV-300i
