New to Clubpolk ..Pls help point me in right direction
Jim999
Jim999 Posts: 4
edited June 2006 in DIY, Mods & Tweaks
Post edited by Jim999 on
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2006
    Maybe add some polyfill to the cabinet.
  • danger boy
    danger boy Posts: 15,722
    edited May 2006
    Glad that you added the Hafler amp.. that was a good move. Sometimes older speakers tend to not seal as good as they used to when new.
    If a sealed speaker like all the vintage Polks out there still. over time they tend to leak air. Those small leaks don't let the passive radiators perform like they use to.
    You may need to remove the drivers and make sure they are all sealed as air tight as you can get them.
    WHat else are you using for a receiver or pre amp?
    PolkFest 2012, who's going>?
  • danger boy
    edited May 2006
    Jim,
    it's best to post answers in here.. that way.. other people that may have a similar problem to yours. can benefit from the information people post in here.
    welcome!
  • Zen Dragon
    Zen Dragon Posts: 501
    edited May 2006
    Jim:
    Welcome to the forum.
    You stuck with your speakers for 15 years, there must be something you liked.
    You said the Hafler brought out things you had never heard before. Did the Hafler make your bass sound better or worse? Generally when you upgrade to better solid state amps you get better bass.
    Room placement can improve your bass as well. Make sure you have a solid back wall behind your speaker, type of flooring, and how they are set up in relation to the floor can affect bass as well. Some other great advice on this thread.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • michael_w
    michael_w Posts: 2,813
    edited May 2006
    I don't know if it'll help much with cleaning up the bass, but if you want to test if they're sealed all you have to do is lightly push in the passive radiator and hold it in. As you do this watch the mids. If the cabinet is truely sealed the mids should push outwards and hold in that position. What will most likely happen is that they'll slowly creep back into their usual position, but if they go back quickly even though you maintain a light pressure on the passive radiator you have a sealing issue.
    My Monitor 7b's weren't sealed well when I got them. The back pannel vibrated and rattled when I turned them up a little so I had to take out the drivers and seal all the corners with some kind of caulking (can't remember what it was exactly).
    Placement might be an issue here. I don't know how you have them placed now but if you can try and bring them out of any corners as well as off the back wall. You'll loose a lot of bass but it should sound a lot cleaner.
    Good to see another person from Vancouver join the forums. I think that makes four of us now? Welcome to club polk. trink39.gif
  • Jim999
    Jim999 Posts: 4
    edited May 2006
    hello ???? duhhh, what's going on here???
  • Jim999
    Jim999 Posts: 4
    edited May 2006
    Oh my, I see what is happening... will have to think out what to say here... for one thing, Thanks to all who responded to my posting - never expected such a large and gracious response. I'll be back when I get my thoughts organized,, not much on 'real-time' comms.
    Thanks again for the nice Welcome and good suggestions so far
  • Zen Dragon
    edited May 2006
    It's not necessarily "real time" comms. Just get back in a reasonable amount of time after composing your thoughts. We'll be here.
    Good luck!
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2006
    How far out from the rear wall are they? Try these steps:
    1. Increase distance from rear & side walls
    2. Spike them and place them on tiles if your floor is carpeted
    3. Try a speaker wire like AQ Type 4, AQ Bedrock, or Kimber 4TC
  • Jim999
    Jim999 Posts: 4
    edited June 2006
    F1nut Posts: 51,674
    edited June 2006
    There are a number of things you can do to improve the RTA 15's other than running subs and effing with the mid - high area. Try getting better speaker cable, getting a real pre amp, better interconnect cables and upgrading the crossovers. I think you'll find a whole new level of performance from the 15's.
