Broken speaker RTi10 grille
tledoux
tledoux Posts: 17
edited May 2006 in Speakers
OK, I bought my Polk RTi10's about 3 months ago, and I noticed recently that the front grille of one of the speakers had what looked like a bulge in it. So when I took the grille off, I noticed that there was a slight crack near one of the nubbs that attaches to the speaker. How do I order a new grille or should I just glue the crack?
Fronts: Polk RTi10
Surrounds: Polk TC615i
Center: Polk CSi5
Sub: Velodyne DLS-3750R
Receiver: Yamaha RX-V1600
Amplifier: Outlaw 7500
DVD/CD: Sony DVP-CX995V
HDTV: Sony KP-51HW40
RC: Philips TSU-6000
Post edited by tledoux on
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited May 2006
    I would use a little JB weld to glue it togeter and replace the missing plastic.
    If it doesn't turn out, buy a new grill.
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    a good 12 hour epoxy could work but be super careful not to get any on the grill cloth even from behind because it could possibly show on the outside. You could slide a sheet of computer paper or two between the brace and the grill cloth before you start gluing but I would definately try gluing first. My grills on my 10's are broken in 5 little places but I can't even tell so I don't care.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
