your opinions
Ervins
Ervins Posts: 4
edited May 2006 in Speakers
I consider for audio instalation in my cabinet. 4x5m (13x16 freet)
There is shelves around and corner windows from floor to roof (3x3x8 feet), (that is - no place for Floorstands), 32" plasma, SatTV receiver, Philips 5900 DVD (cheap as toy, but with HDMI).
I consider:
Marants SR 4600 receiver, RTi6 front, RM6902 center, RM6801 rear, still considering Sub.
Budget is not primary, but i prefer spend mony by usefulness.
I do not plan make there any discotek, but i would like to heard my Klaiderman (non SACD) and Ronnie James Dio well. Sometimes i view movies.
Ervins
Post edited by Ervins on
  • steveinaz
    steveinaz Posts: 19,538
    edited May 2006
    Skip the sub since music is your primary focus. Use the money you would have spent on the sub somewhere else.
    Are the Rti6's going to be wall mounted?
  • Ervins
    Ervins Posts: 4
    edited May 2006
    I plan put one simply on shelves near the books other on stand, but is possible mount its on wall. Are is difference ?
    Are i realy fill good if i hear also rock (from 80') without sub ?
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    Man Ervins its hard to read what you type can you try to be a little more descriptive or english speaking in nature because I can hardly understand.... If what you are asking is if you can hang the RTi6's the answer is yes but do not use the screws that come with the speakers. Get some heavier duty ones that still fit throught the key holes on the back of the speakers at your local hardware store.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
