GFA-535 for LSIC ?
gwh
gwh Posts: 1,451
edited May 2006 in Electronics
Some advice needed.
I picked up an Adcom gfa-555 locally dirt cheap and have it running lsi9’s, my lsic and 7’s are being run off my receiver. I’m content with powering the 7’s with the receiver since they are just serving as surrounds, but the lsic does sound a little on the flat side.
I’m thinking about picking up an Adcom gfa-535 for the center.
I would split the signal out at the receiver and input into the L & R inputs on the 535, then wire up one set of binding post on the c with the left output, the other with the right.
Would I be fully utilizing this amp by wiring that way?
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
    heiney9 Posts: 25,217
    edited May 2006
    Good choice it should work out very nicely. Then your whole front stage will be timbre matched by using the same series of amps. The 535 is a gutsy little amp.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I think it would sound good if I remember what I have read about that amp correctly.
    Bi-amping the center should make it light up.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
