Antonov AN-124
janmike
The Diamond mines contracted this puppy for a day to transport material and equipment to site. The weight was larger than the Mi-26 could lift.
Here are some specs:
Wing Span 240 ft, 5 in (73.3 m)
Length 226 ft, 3 in (69 m)
Height
Weight 405000 kg
Engine 4 - Lotarev D-18T, 229.9 kN thrust each
Maximum speed
Cruising speed 865 km/h
Range 16,500 km maximum range
4,500 km with maximum payload
Service Ceiling 12000 m
Armament none
Payload 88 passengers or cargo in a 36.5 m x 6.4 m x 4.4 m (1027.8 cu. m) cargo bay
Crew Six--seven with loadmaster
Height
Weight 405000 kg
Maximum speed
Armament none
Michael
NORTH of 60°
NORTH of 60°
Ah, the old Soviet CONDOR. I got to write a paper for CINCSTRATCOM on a VTA CONDOR that crashed trying to fly out of Irkutsk in Dec 97; the aircraft smacked into an apartment building.
The "C-5ski" is what it is commonly called. The Russians were/are very good at technology theft. They made it a couple feet longer than a C-5 so they could claim the worlds largest aircraft. I walked around inside one at the big air show held annually in Melbourne, Australia. That was in 1992. The Russians were so broke by that time, that while everybody elses aircrews were living downtown in 5 star hotels, the Russian crew was lodged in their own airplane. They didn't even bother to remove the hammocks and other bedding prior to the walk through tours.
Thats a big bird but the Russkies had another trick up their sleeves....they stretched the fuselage, added wing area and added another two engines so they could transport their version on the space shuttle (Buran). This behemoth is the Antonov AN-225 Mriya or Cossack. I believe only 2 were built and they are now used as specialized airborne freight carriers.
I have seen footage of this airplane on Discovery Wings channel a few years ago and the footage showe the aircraft cicling the field slowly in very tight turns and steep banks! It was quite impressive to see something that big move like that!
I also really dig watching C-5's and other large aircraft come in for landings...their large size makes them to appear as if they are floating in the air!
Cool pics...thanks for sharing!2 Channel Rig
Source 1 - Apple TV
Source 2 - Parasound D3 Universal Player
Source 3 - Parasound Tuner T3
Pre-amp - Parasound HALO P3
Amplifier - Parasound HALO A21
Speakers - Martin Logan Vista
Power Conditioning - Panamax M5100-EX -
I've dealt with the AN-124...it's garbage. Trying to load those things suck.
The IL-76 is just as bad.
Back in the day when I got to take the Dover AFB tours the guys let me left seat a C-5 (on the ground of course) and there is no telling how many times I lost track of where our car was on the track when they would fly over during the race. Amazing aircraft
polkaudio SRS (rdo194 x 8)
Dodd ELP (separate power supply)
JC 1 blocks ( strapped )
Rega Apollo
MIT (speaker cables) Outlaw (ICs)
polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
B&K 505
Samsung LCD
VIP 622
HSU STF-2 -
Wow. That's big. I would like to see it in a banked turn in the air!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
The C-5 has 28 tires on it. The gear system is a hydraulic nightmare. The aircraft needs to be put on jacks for gear maintenance to be performed. Which leads me to the age old aviation joke......
"What does it mean when you go to a C-5 base and there's only one C-5 up on jacks?" -
It means they only have one set of jacks on that base.
audiobliss wrote:Wow. That's big. I would like to see it in a banked turn in the air!
thats what my wife......ah ,never mind,wrong thread.:)HT SYSTEM-
lsi 9's -
The only bigger PITA than the C-5 itself are the crews that fly them
