Best way to run two subs
What is the best way to run two subs off a receiver???
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Depends on the subs and the receiver.
    Some receeivers have two or more sub outputs and some subs have crosovers which will allow you to use the pre/outs for the left and right channels to power them.
    So it depends on what you have or are looking to buy.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • dkg999
    dkg999 Posts: 5,647
    edited May 2006
    The most common for Home Theater is to use a Y adapter to connect the LFE input for each sub to your single LFE output on your Home Theater Receiver. You can then use the volume control on each sub to adjust for room placement. This gets you the basic setup prior to any frequency equalizing that you might do. For music you might opt for each sub to be hooked up to the high level speaker outputs of your receiver, and then your main speakers hooked up to the high level speaker outputs on the sub. You then use the cross-over on the sub to control bass between the sub and your main speaker.
    DKG999
