I need a sub for my LSi system
confused1234
I have the system listed below in my living room. The room is 12'x19'. Do I need a seperate sub to go along with the two subs in the LSi25s?
TV - Pioneer Elite 1130HD
DVD - Pioneer Elite DV-79AVi
Receiver/Preamp: - Pioneer Elite VSX-72TXV
Amp: - Outlaw 770
Speakers
Front - LSi25
Center - LSiC
Surround - LSiFX
Cables: Blue Jeans Cables
Amp: - Outlaw 770
Speakers
Front - LSi25
Center - LSiC
Surround - LSiFX
Finally an Amp: - Sunfire Cinema Grand 200~5
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
NOW :eek: Gotta find a suuuuubwoofer!!:eek:
Speakers
Fronts - LSi25
Center - LSiC
Surround - LSiFX
Post edited by confused1234 on
only if you think you need a sub. a seperate sub will pick up where your LSi25's drop off... for some people a seperate sub is a must have.. for other's it's not that important.
do you listen to music or movies with your system?PolkFest 2012, who's going>?
If you use your system for movies then yes you need a good sub. Unfortunately there is not much under $500 that will provide you much improvement over just running your LSi25's.
I would say yes (for a video system not just multi channel music) you need a sub but don't worry about purchasing one until you get $750-$1200 together to purchase one. (then audition and get the best one you can for the money)
Michael
BTW - yes, I did pull those price figures out of my ****, but if you spend much less than that - there is a good chance it will be wasted as it may not provide the improvement you are trying to get.
A much cheaper option (since you have the 770 with a 5.0 system) would be to go with an IB or DIY sub and run the sub off the left over channels from your 770. If you go that route - ignore the prices listed above.......Mains.............Polk LSi15 (Cherry)
