Help With CSi5: What stand feet should I use.
brockmouse1
brockmouse1 Posts: 4
edited May 2006 in Speakers
Hi,
New to this Forum.
just setup my system, RT12's x 4, and the CSi5.......At the moment its sitting under the Television on a very thick glass shelf, and with the small rubber feet that came with the speaker.
Is that OK?? or does anybody have any better sugestions??
thanks for your time.
I'am worried about vibration etc,etc.
MY SYSTEM
Yamaha RX-V2500
VINCENT SP-998 x 3 Mono Amps
Polk RTi 12 x 4
Polk CSi5 Center
Polk Subwoofer
Post edited by brockmouse1 on
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    should be ok, have you seen polks page on the CSi5? It shows how it is designed for your aplication.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
