mm120s
sntnsupermen131
Kim,
Is Rockford Fosgate's matrix gamma the best RCA cables to buy?
I was wondering because I installed my system in this weekend and was wondering if that was the best wire to go with
one more thing, from the mm120s, to the terminal, to the amp, what size wire would you need?
is 12 big enough or is it too small??
about how efficient should a 1000 watt amp be?
im going to order a capacitor today off of ikesound.com and as soon as i get it ill install it
and is there any way you could send me 1 on the papers with the foam pads that go on the back of the mm120s so they wont leak air??
like can i give you my address and you send them to me?
if you can its:
Cody Stewart
14514 FM 3089
Sinton, Texas
78387
thanx again,
-Cody
if you can its:
Cody Stewart
14514 FM 3089
Sinton, Texas
78387
thanx again,
-Cody
Post edited by sntnsupermen131 on
thanx kim,
but are they good rca cables??
i have a RF bd 1000.1 and the efficiency is 64% and i was wondering if that was good for this type of amp?
and what about the foam surrounds?
thanks
-Cody -
thanx a million kim
--the reason i was asking about the rca's is because they run like 60 bucks at best buy
one final question
per chamber(.88ft^3), how much poly fill should i put in it?
-Cody
