Gauge wiring for C400.4 and 500.1
theterriblepig
theterriblepig Posts: 1
edited May 2006 in Car Audio & Electronics
Ok first here's my current setup:
Alpine CDA 9831
Polk/MOMO MMC6500
Polk/MOMO MMC650
Polk/MOMO C400.4
MTX SLHT5510A
I have an MTX SLHT5510 Sledgehammer box w/ 10" MTX 5510 woofer (300W RMS @4 ohms) currently powered by a POS no name 2 channel that i was given for free (now going to my brother). I just got a C500.1 (350W RMS @4 ohms), and currently have the Metra/Tsunami AMP1220BL wiring kit, which is basically 4 gauge running to a distribution block that runs 8 gauge to each. Is it safe to run 8 gauge to each amplifier?
Post edited by theterriblepig on
  • MacLeod
    MacLeod Posts: 14,358
    edited May 2006
    Yes but 4 guage would be better and 1/0 from the battery and then 4 to the amps would be ideal.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited May 2006
    I would go bigger than the 4ga if you are going to redo the wire run. Since you already have a 4ga run, I would just purchase another 4ga. This way each amp will have it's own 4ga power cable, and it will cost less.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • cam5860
    cam5860 Posts: 632
    edited May 2006
    If your running a 4 channel amp 8 gauge is fine to run if your running components off of it.
    Components don't pull large amounts of current like subwoofers so it's not hurting your performance any.
    But when your running subs on any amp you need at least 4 gauge wire. Subs draw huge amounts of current.
  • MacLeod
    edited May 2006
    It depends on the amp and its current draw.
    You wouldnt necessarily want to run 8 guage to a Crossfire 8004 which puts out about 150x4!
    Same with sub amps. There is no need to run 4 guage to a 300x1 mono amp.
  • cam5860
    cam5860 Posts: 632
    edited May 2006
    8 gauge wire will pull 60 amps of current thats about equal to 100 rms x 4 or 400 watts rms.
  • MacLeod
    edited May 2006
    Which would be less than the 600 put out by the 8004, especially if you ran it at 2 ohms stereo which would be over 800 RMS. Way too big for 8 guage wire.
  • exalted512
    exalted512 Posts: 10,734
    edited May 2006
    theres a little more to current that determines the size of wire you need...and wire does not "pull" current
    -Cody
  • 1996blackmax
    edited May 2006
    Something called length is one of them I believe ..... :)
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • unrealii
    unrealii Posts: 268
    edited May 2006
    LSIm system on order =D
    Currently listening to innovation...
    Prior car systems:
    Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
    Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
  • cam5860
    cam5860 Posts: 632
    edited May 2006
    The amp pulls the current but the flow of current flows through the wire smart ****. My point was about 60 amps of current draw is about all 8 gauge can handle.
  • MacLeod
    edited May 2006
    Agreed.
