Polk Audio THX Certified Subwoofer?
SouthEnder
SouthEnder Posts: 6
edited May 2006 in Speakers
I have a client to whom I am prepared to pitch installing a combination of LCI-RTS105s as the LCR speakers plus four LCi-RTS100s for the side and rear surround sounds. The value prospect, in part, is the THX Ultra 2 certification of these speakers since this home is being built on spec. We have tentatively discussed dual CSW200s as in-ceiling subwoofers, but they are not currently THX certified. Does anyone know if Polk is planning on or in the process of having them certified? If not, what do I install in order to be able to rubber stamp the installation as THX Ultra 2 certified?
Post edited by SouthEnder on
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    If the room is being built to Ultra2 specifications, that's the main idea behind the certification in the first place.
    "While THX Ultra2 Certified Products are dependent on the room size, THX Ultra Certified Products are not. THX Ultra brings high end performance to interconnects, equalizers, projection screens and DVD players, complementing the THX Ultra2 category."
    You just want the subwoofer to be formally certified? The application in regards to subwoofers is also room dependent, as in the rating for that subwoofer per cubic feet/volume. It also covers a host of performance qualities like flat response to 20hz, high SPL at 80hz....and some other interesting tidbits.
    I don't think it would be an issue....BUT this would be best answered by someone from Polk as opposed to a few board junkies like myself....I'll drop a line to someone nifty today.
    F1nut Posts: 51,782
    edited May 2006
    The "Polk Paul Kick Butt" certification seal of excellence is good enough for me.
  • dorokusai
    edited May 2006
    Jesse - You have no idea where those hands have been....you sure about that?
    F1nut Posts: 51,782
    edited May 2006
    WAAAAAAAAAAAAAAAAAAA
    Good point!
  • dorokusai
    edited May 2006
    We only poke those we love...well that didn't sound right. Go ahead and file the restraining order....
  • faster100
    faster100 Posts: 6,124
    edited May 2006
    dorokusai wrote:
    We only poke those we love.... ....
    Ah that explains it.. :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
