New Sub!
1996blackmax
1996blackmax Posts: 2,436
edited May 2006 in Car Audio & Electronics
Arc Audio Arc Series 12D2 :D. Should get this going in by today.
Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
Post edited by 1996blackmax on
  • audiobliss
    audiobliss Posts: 12,518
    edited May 2006
    Hurry up and get that thing in there! Then crank it! I wanna hear it! :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • 1996blackmax
    edited May 2006
    Will do :D. I am going to go by a couple of shops to check out the sub boxes.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • 1996blackmax
    edited May 2006
    Ok, been busy dealing with car issues....
    Got the sub in this weekend. The box volume is about a cube after taking into account the driver's displacement. The thing sounds very nice, and it has the extra punch that I wanted. Always nice to get a little more pronounced low end :).
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,735
    edited May 2006
    did you not have a sub before???
    i guess youre running it in series at 4 ohms? I want new stuff!!!! My new 8" midbasses should be here anyday:D
    -Cody
  • 1996blackmax
    edited May 2006
    I did have a sub. It was a Sounsplinter RL-i10. That sub is a very nice sub, produces clean bass, and has nice outpout (has 20mm of linear excursion). I wanted a little more oomph in my low end, and this sub did it. I do have it wired for a 4ohm load. My amp puts out about 400 watt RMS. This sub has 16mm of linear excursion, this along with the added cone area (compared to my 10" sub) works out nicely.
    8" midbass drivers... yummy :D.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    edited May 2006
    ahhh thats right, forgot about the SS. If/when my brahmas blow, ive been thinking about them
    -Cody
  • 1996blackmax
    edited May 2006
    I would have gone with the RL-p from them, but my amp in the size of box that I wanted would not have worked to my satisfaction. The 12" requires about 1.5 cubic feet, you can get by with 1.33 or so, but with 400 watts it may not have been a good match. With the Arc sub, I have it in the sweet spot for the box volume, and have it powered properly.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
