Pioneer cd player
jayman_1975
jayman_1975 Posts: 672
edited May 2006 in Electronics
Hey guys..anyone know anything about this model PD-4350. I can't find info about it on the net. I can get it for next to nothing at my local thrift store..course that may very well be all it's worth...only thing i know is it says 4* oversampling on the front. Anyone know if it'd improve my sound any better than the chepo toshiba player i'm using as a source right now?
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Post edited by jayman_1975 on
  • danger boy
    danger boy Posts: 15,722
    edited May 2006
    sorry. i don't know anything about it.. back in those days different CD players were released nearly every day. just do a search on Sony CD players.. and you'll get like 1,0000000000000000000000 hits..
    Problem with 4 times oversampling.. is it could skip. 8 times oversampling is the least i'd use. I'd say pass on it.
    PolkFest 2012, who's going>?
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    That's funny.
    EDIT: I'm not commenting on your CDP Jayman...just the Oversampling statement.
  • George Grand
    George Grand Posts: 12,256
    edited May 2006
    It would be fine for a garage rig.
  • danger boy
    edited May 2006
    find yourself a used NAD on the cheap... they sound good and used ones don't run much dinero. only problem with the NAD's... is their displays are notorious for going out. I've had to replace way to many to count.
    or you could just keep using your Toshiba
  • danger boy
    edited May 2006
    the Pioneer PD-4350 built in 89 and 90. 16bit, 4X OS. used goes for about $7
  • jayman_1975
    edited May 2006
    thanx for the info..i figured it wasn't anything special i just hoping to maybe get a little improvement over my toshiba for cheap. I'll pass.
    Arcam CD37
    Vandersteen V2W
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited May 2006
    What does oversampling have to do with skipping?
  • dorokusai
    edited May 2006
    Nothing, unless you're banging your head on top of it in a drunken rage.
    heiney9 Posts: 25,497
    edited May 2006
    I over sampled some Rum last night and now my head hurts. I didn't even have to bang it on the cd player ;):D .
  • danger boy
    edited May 2006
    Oversampling in the context of the D-A process involves multiplying the sampling frequency by a whole number, typically between 4 and 32, or even higher. For example, in ‘8x oversampling’, CD’s base rate of 4.4.1kHz is raised to 352.8kHz by introducing seven new ‘empty’ samples between the original data samples. These new samples, though, are often not just empty strings of noughts, but based on mathematical models to assist the DAC to work more linearly with the extracted data.
    Oversampling, as well as easing the workload of the anti-aliasing filter, which can now operate more gently at a higher frequency, can also reduce distortion created when those analogue signals are first turned from continuous, analogue waveforms into stepped, digital, stair-like curves. This quantization noise is now spread over a larger band after oversampling, and can even be somewhat shifted out of the audible envelope by the technique of noise-shaping. Sony/Philips’ Direct Stream Digital, as used
  • dorokusai
    edited May 2006
    Do you honestly think you could hear the difference between a 4x vs 8x CDP?
    If you want to hear a night and day difference, check out a first generation CDP, Kyocera or Phase Linear vs a modern CDP....that's audible.
  • danger boy
    edited May 2006
    no. i think a 8 X and above will track better than a 4x oversampling is all i'm saying. like many a folks on here, who purchased their first CDP.. the first affordable consumer CDP were mostly 4x oversampling.
    Some of those had some problems reading the discs.... that has largely be solved now.. i don't know of any current CDP that still use 4x oversampling. why? because things have improved.
    That's all i'm saying. I"m sure a 4x oversampling player will read a CD... but if given the choice.. i'd pass on a used player that only had 4x oversampling.
    edited May 2006
    Not trying to bust on ya DB, but oversampling has nothing whatsoever to do with tracking/error correction. Two completely seperate issues. Tracking/error correction is handled by a circuit known as CIRC, see linky
    http://en.wikipedia.org/wiki/Reed-Solomon_error_correction
    Now, they do use the term oversampling, but it's completely different in regard to how the data (bits) is used. When you are talking about 4x vs. 8x oversampling it's not refering to error correction and the associated (over) sampling that takes place to replace damaged or dropped bits.
