How do i keep my db 650s from moving?
TheShadBoy
I recently bought a pair of db650s to go in my 1994 ford aerostar (yes a minivan:cool: ). The only problem is that the factory speakers only had three screws, and the 650s have four. So, me, being my lazy self said what the heck, and only screwed one screw in. Mistake. Nothing broke, but sometimes going over speed bumps causes them to jump, and i was wondering what i could do to fix the problem.
Thanks in advance for your help.
brian
brian
ME
1 1994 ford aerostar w/197,000 miles and counting
1 Sony deck
2 Polk db 650s
2 Sony 6x9's
I Polk amplifier
"At least its a dry heat"-Arizona
1 Sony deck
2 Polk db 650s
2 Sony 6x9's
I Polk amplifier
Post edited by TheShadBoy on
take a small drill bit drill holws through the metal at each screw hole, and put screws in, or you could be lazy and use double sided tape between the panel and the speak, just make sure you clean both surfaces with alcohol first to get a good bond(not beer or jack, rubbing alcohol).
Thanks a lot. The movement has been worrying my mom a bit, so i decided to seek expert advice (you guys).
I will try the tape cuz that sounds easier and i am not ashamed to say that I am a little lazy.
Thanks again!!
brianME
1 Sony deck
2 Polk db 650s
2 Sony 6x9's
I Polk amplifier
