Virus message....Time to format my drive?
Mike682
This Norton Antivirus message popped up while at this site a few minutes ago. I think it was just a coincidence that it popped up here because every once in a while this message will pop up regardless where I am. Norton's is always able to delete it but this trojan was/is in my sys files and I have a feeling it is just renaming itself and Norton's keeps finding it..Running virus check in safe mode finds nothing..
Looks like a format is in order
:rolleyes:
:rolleyes:
Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29
Mains: polk R30
Center: polk CSi3
that link froze my computer. anyway, looks like it took three attempts, but finally deleted the virus, yes? stay off the **** sites! ...who am i kidding?:rolleyes:
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
I wasn't able to see the file name clearly enough to identify, but you may want to run a spyware scan before you go to the trouble of formatting. My favorite program lately is ewido (http://www.ewido.net/en/). Seems different programs are more effective at different times, used to be Spybot, Adaware, etc. They all can find things the others don't, usually.
Thanks for the replies guys. Thanks for the link dylan. The word file has a clearer picture of my warning screen.
I ran that program and it found one item which I deleted. At least it found something, Spybot and spywareblaster did not find anything.
I'm going to see what happens this weekend. I have all my discs ready for re-installation if needed...
MikeReceiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
DVD: Panasonic DVD-S29 -
There's more info here too (trojan.galapoper.a). Might be a good time to stop/ restart your system restore feature in XP, as this will clean out old restore points that contain infected files. Info.
Get rid of that "Symantec" program so you don't have those popups. That should solve it.comment comment comment comment. bitchy.
I would suggest Webroot Spysweeper and McAfee Stinger. Both are very good programs and we use them on my work site.My Living Room 3.1 config:
Toshiba 40RV525U
Receiver: Onkyo TX-NR609
Center channel: Polk CS1
Front L/R: Paradigm Reference Studio 20
Subwoofer: Velodyne DPS-10
Rears: None
My Computer setup
Klipsch Pro Media 2.1 THX
