how far apart do i space bookshelfs on wall
faster100
I am changing my small room around and have a small space now for the 2 channel.. whats the rule of thumb for spacing? I have RT25i speakers mounted on the wall.. right now i tried 32" apart and 35" to the bottom of the speaks off the floor... wood slat wall behind, open doorway on the right.. corner on the left.. lemme know.. its about 6-8' to the seating from the speakers
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
There is some kind of triangular formula regarding your listening position and speaker placement, but I don't remember what it was.
Of course, just do what sounds best. -
isnt it, the space between speakers is the same as the space from your seat to the speakers?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Yea, rule of thumb is an equalateral triangle between the spooks and seating area.There are two ways to argue with women. Both of them are wrong.
However another rule of thumb is to give the spooks as much room to breathe as possible. ie no corner placement. couple of feet behind and to the sides is optimum.There are two ways to argue with women. Both of them are wrong.
Thanks guys and polk paul... for the help. will continue to tweek placement tomorrow as i redo this room.. paint is next.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Polk Paul got me searching. I must say, very interesting. Wonder if these things are for real or snake oil?
http://www.6moons.com/audioreviews/roomlens/roomlens.html
