Need help matching mains to my center
Hey guys,
I was looking to upgrade my Infinity Reference speakers that I have had forever.
Someone recently gave me a Polk CS400i center channel and I was looking into building a system based off of that center. I have been interested in the monitor 70 or the RTi8 for the front mains. Which ones would match my center the best?
I will be running off an Onkyo TX-SR503.
Post edited by s13_drift on
Welcome to the club,
If it were me I would look for the RT series that was available when that center was new.
I used to use the Rt2000p's for my left and right duty in my HT rig.
They are not the best for 2 channel listening but were good for HT.
The Rt800i's would also be a good match if you have the patience to find them.
I have never heard the monitors or the rti8's so I will not comment on them.
Good luck to you.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
if you can't find any of the older RT models the RTi8 will be a closer match to your CS400i than the monitors, I used a CS400i and a set of RTi6's in my HT for about a year with no problems.Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
Thanks.
I will keep an eye out for the older RT models.
I came across some RT800's is there a big difference between the 800 and the 800i. Since the center is an "i" is that what I would want to stick with?
I'm not sure if there is anywhere in Oklahoma City where I can actually go listen to the RTi8. The only place I found so far is CC and they only carry the Monitors. -
People say they hear a difference between the two but my ears are not that great.
I would try to match them just because I am like that.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
