Hooking up Sub to pre-outs
dipiazza
dipiazza Posts: 363
How would you all reccomend i do this?
I am running a Teac A-1D integrated, and it has a set of pre outs. Would it be best to run a sub with a pair of RCAs, 1 Left and 1 Right all the way to the L&R imputs on the sub, or should i use a Y cable to take the L&R channels into 1, and then run a single cable off that to the sub?
-Jake
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
Post edited by dipiazza on
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    I would not combine my left and right channels into a y-splitter. This just sounds like a bad idea.
    I would either run the left and right rca cables all the way to the sub or use the lfe output and a splitter to the sub.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • dipiazza
    dipiazza Posts: 363
    edited May 2006
    The teac has no LFE output or Xover, but i see you would go with seperat cables...
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • unc2701
    unc2701 Posts: 3,587
    edited May 2006
    don't combine L&R with a y cable. You need an isolation transformer to do that properly.
    Backburner:Krell KAV-300i
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2006
    That's funny, is everyone smoking the wacky weed today?
    Combine away, if you aren't running stereo subs, don't worry about stereo bass. Signal Cable and Audioquest both make a decent RCA Y cable, for not a lot scratch. Get a single decent interconn to make the rest of the trip.
    Just throwing that one out, it IS ok to do. Me, I'd just buy a single (long) pair of decent interconns and call it day.
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    Is it truely ok to combine a stereo signal into a mono signal?
    I just thought the processor would not like to see the positive left and positive right make contact.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • unc2701
    edited May 2006
    ITS RISKY! Ok, this is coming from some live sound applications, but it probably applies to some preamp (pre out) designs- you can damage gear combining left/right preouts. Seriously- just get a pair of 600 ohm 1:1 isolation transformers from radio shack, wire oneside of each to the left and right preouts, then combine wires from the other side.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2006
    You know a Y-Cable is a gateway interconnect right? :)
  • madmax
    madmax Posts: 12,434
    edited May 2006
    I would never use a Y connector to combine the signal at the pre output. It may be forgiving for awhile but it is a good way to fry one of the outputs. If you run dual cables to the sub it would be ok because each of the sub inputs is somewhat isolated from each other.
    madmax
    Vinyl, the final frontier...
  • dipiazza
    dipiazza Posts: 363
    edited May 2006
    wow, lots of disagreement here.
    the only reason i wanted to go with one cable is simply for price sake, and being able to run a single one out to my sub. It seems that either way could work though.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • unc2701
    edited May 2006
    Let's put it this way: some of us think that you could bake your gear using a Y cable on the preouts. An extra cable doesn't cost much... so why risk it?
  • ironmike86
    ironmike86 Posts: 23
    edited May 2006
    The rca cable? You can run a rca cable put a y at the sub attach another cable from there? Or a y on a preout. Never heard of frying your gear with a y from sub out?
  • Skynut
    Skynut Posts: 2,967
    edited May 2006
    It is not a problem with a y from the sub out it is a problem with hooking up the left and right pre/outs to a y that combines them into one signal.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
  • RuSsMaN
    edited May 2006
    So who has blown something up, seriously? I've never had an issue, and do the same thing frequently with mono amps (old tube gear).
  • unc2701
    edited May 2006
    When I was in a band our keyboard player fried a midi module doing that. We didn't feel like rugging the amp with multi inputs, so he just used a Y- to combine the L&R. About two minutes later, *PFOOOF*. I suspect that anything with output transformers will be safe, but a lot of SS gear will be susceptible.
  • dorokusai
    edited May 2006
    Russman - I guess they've never heard of or seen a shorting bar.
  • dipiazza
    dipiazza Posts: 363
    edited May 2006
    Well thankfully this was all resolved.... heh.
    I dont really see how it could "fry" the pre-outs but, going 2 RCA isnt that big of a deal.
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • wire
    wire Posts: 32
    edited May 2006
    -Jake
    Frik
    Just use a good Y cable out of your left or right channel pre out . The Y will go to 1 to amp and 1 to Sub .
    Try and use a good Y jack (1 male and 2 female ) , so you dont lose to much signal and good inter connects .
    Ive been doing this with my Carver CT-17 since i got it new and nothing has fried .
