anyone heard of OneAC line conditioners?
faster100
I picked one up used at the flea market model cl11007
output says 120 vac and .625 amp is that low? on amps or does it matter with a line conditioner.. could you use it for an amp or pre? it was sold with some computer stuff so i assume it was for a computer at some point maybe.. looks just like this one
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
I have never experienced one of these but I am in the market for a new conditioner.
I say hook it up and report your findings but that is just because I am curious.
.625 amps sounds too low for anything, I am not sure what to think about that.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
the website said, under the specs... Load 75 VA
I tried my pas pre on it and it worked fine.. not sure if it hindered, helped or anythingMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I own the Panamax 5510 and at first hooked everything up to it. It is rated at 15 amps.
I noticed my bass went away but it took me a few movies to notice how much it had changed.
I read on another thread here that the wrong power conditioner can limit the reserve power available to your system. This was the case with mine.
I went home and plugged my powered subs into the wall and the bass was back.
This last weekend I plugged my amp directly into the wall but already I have problems. When the system is on and I turn off the ceiling fan I get a pop sound that comes from my speakers. I am sure this has to do with the amp not being isolated from the fan circuit.
Now I am looking for a conditioner that is built for amps.
PSAudio upc 200 was recomended F1nut in this thread
I have not had the money to buy one or two yet and I am now thinking about getting the Power Director 4.7 to replace my Panamax.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
figured as much, it may be good for my computer i guess or maybe the tuner or cd player.. wow 2k for a conditioner... that should work goodMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Don't waste your money on a conditioner, ANY conditioner.
Get a dedicated line, and if you feel the need to take it all the way, add a balanced power supply.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
My Panamax is balanced, but it changed the preformance of my amps.
It works great with all the other components, the t.v., dvd, sat, vcr, just not the amps.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Your Panamax isn't true balanced, how they get away with claiming it is, I have no idea.
I'm talking about a straight, balanced power transformer, no circuit massaging, filtering, etc etc. 60 on each rail.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
RuSsMaN wrote:Your Panamax isn't true balanced, how they get away with claiming it is, I have no idea.
What do you recommend?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
He said a dedicated line is bestMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I don't have a dedicated line and was interested in his opnion for a balanced power conditioner.
I should save it for another thread.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
What is a balanced power supply?
Balanced power is 60 volts on each leg of the power cable instead of 120 comming in on the hot and the neutral having 0.
It is supposed to alternate -60v and +60v on the hot and neutral.
I think.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Nah i got what i needed, carry on.. hereMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Skynut wrote:Balanced power is 60 volts on each leg of the power cable instead of 120 comming in on the hot and the neutral having 0.
I think.
So it's an isolation transformer?
Not really sure what it would be called.
Mine has a large transformer in it and when I had all components running through it, it would hum. I could not hear the hum out of the speakers just when I was close to the rack.
It says it provides balanced power but RuSsMaN says it is not.
I have read that there are many power conditioners out there claiming to be more than they are and I had hoped mine was not among them.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
