iPod Headphones
apc
apc Posts: 779
edited May 2006 in Music & Movies
Can't stand the earbuds that it came with it. They hurt my ears before too long. From a comfort point of view, which brand and model do you prefer?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • brettw22
    brettw22 Posts: 7,623
    edited May 2006
    I use the Sony Fontopia's. They're super light and fit within the ear canal so you don't have to listen as loud, and they block out external sounds. They're EXCELLENT for an airplane, but might be a bit too quiet for walkin around the city.
  • Demiurge
    Demiurge Posts: 10,874
    edited May 2006
    Yeah, the earbuds that come with it suck. They keep falling out of my craw, even when walking.
    If you're going to be out and about you can get something that wraps around your ears so they stay put, but if you're doing at home listening get a pair of Sennheiser or Nady.
  • dbnh
    dbnh Posts: 194
    edited May 2006
    Try going to Head-Fi and perusing the headphones and portable audio forums. There's some very nice IEM and other phones out there, depends on how much you're willing to spend.
    Also, I'd recommend a portable amp. There's also lots of information of that. I use a Xin SuperMacro3 V6; could also recommend Ray Samuels' Hornet and SR71, various amps from HeadRoom, etc. Again, the question is: how much do you want to spend?
  • apc
    apc Posts: 779
    edited May 2006
    The Sony Fontopia's look inviting as well as the Ultimate Ears super.fi 3 and the Etymotic 6i Isolator™ Earphones. All around $100 depending where bought. I'd appreciate any reviews which would key on comfort. At this pricepoint the sound quality would have to be a step up or more from OEM.
    PS - I am intrigued by the amp option, but more for home (Senn HD595) use than portable. Thanks for the info and links!
  • Refefer
    Refefer Posts: 1,280
    edited May 2006
    The Ultimate Ears Super.fi 3 sound very very good for their price range, but are still earbuds (which I've always found get annoying after awhile, no matter how "comfortable" they are).
    As for headphones for portable audio, I prefer the Sennheiser HD 280 Pro. They run for $99 or so, and I use them because I find them very comfortable, though not an earbud but a wrap around enclosure. They also sound very very nice while providing very good sound isolation. Another benefit is that they sound great without an amp and thus can be driven easily by most portable (I use an iRiver because I like my music in FLAC and OGG).
    Happy hunting.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • apc
    apc Posts: 779
    edited May 2006
    What is FLAC and OGG?
  • Demiurge
    edited May 2006
    FLAC = Free Lossless Audio Codec
    OGG = Open multimedia bitstream container format
  • bobman1235
    bobman1235 Posts: 10,822
    edited May 2006
    FLAC is a lossless compression algorithm. OGG is similar to MP3, some people say better quality.
  • Toxis
    Toxis Posts: 5,116
    edited May 2006
    If you want good headphones for the money, check out the Technics RP-DH1200 studio monitors. Can be found for $110-150 depending on the site.
  • mulveling
    mulveling Posts: 505
    edited May 2006
    For sound quality, comfort, portability, and value, it's impossible to beat the Koss PortaPro. Small and lightweight so they'll work well with an ipod on the go. Don't need an amp to sound excellent, though they can improve with one.
    The styling is from 1984 (literally; they've been in production since then) so make sure you look before you buy :D
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • faster100
    faster100 Posts: 6,124
    edited May 2006
    100 -150 to listen to an ipod? Come on.. Home phones if i were into them easily or more.. Ipods, NO. Just IMO
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • brettw22
    edited May 2006
    I guess if he was asking "what do you think about me spending around $100 for headphones", that reply would be relevant.......but he wasn't...........so it's not.
  • faster100
    edited May 2006
    I was stating my opinion on the cost of phones for Ipods.. don't like my opinion don't respond.. simple :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Holydoc
    Holydoc Posts: 1,048
    edited May 2006
    This entire area of Ilounge is dedicated to the discussion of the good and bad about IPOD headphones. Have fun reading:
    http://forums.ipodlounge.com/forumdisplay.php?f=43
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
