Comparing 3 subs....
pushkanak
pushkanak Posts: 45
edited May 2006 in Car Subwoofer Talk
Hi, I am trying to choose the most powerful sub between 3 choices I'm actually considering. When I mean "powerful" I mean the sub which sounds louder and the sub the moves the most air of all.
The 3 choices are the following:
* A SQUARE Kicker Solo-Baric S15L72 that's got 15 inches, 1000 RMS of power, double coil, works at 2 ohm.
* A round JL Audio, which is 15 inches and it's got 1500 RMS of power, it's also double coil, works at 2 ohm.
* Two round Kicker CVX15, each one of them has got 15 inches and 1000 RMS of power, double coil, works at 2 ohm.
Let's supose that in each of the cases I got the necessary amp to power them to the MAX.
I appreciate your responses concerning this thread....
Post edited by pushkanak on
  • neomagus00
    neomagus00 Posts: 3,899
    edited May 2006
    offhand, i'd guess the solobaric... depending on which JL you're talking about, it may or may not be in the running... the CVX subs aren't as loud individually, but it's possible that the extra 3 dB from getting two would let it happen.
  • pushkanak
    pushkanak Posts: 45
    edited May 2006
    I made a little mistake posting the thread. The second choice, the JL Audio, isn´t really 15 inches, is of 13 inches and it´s got 1.5 ohm of impedance. The exact model is 13w7, and you can see it at http://mobile.jlaudio.com/products_subs.php?series_id=10.
    So, do you think that the additional 3 decibels from both CVX´s can beat the 1500 rms of power from the 13w7?
